02-07-2019 18:02
02-07-2019 18:02
My Ionic had about 15 percent charge but then just went blank. I hooped it up to power and it came back to life but the battery charge will not go above zero. I have restarted it and turned it on and off multiple times. I cleaned the back contacts with rubbing alcohol and I have tried multiple charging sources and two different cords. Any other ideas?
Best Answer02-08-2019 00:03
02-08-2019 00:03
@Claygr welcome to the Community. Sorry to hear you have been experiencing an issue. It sounds like you have carried out all the usual diagnostics for this. I would now suggest contacting Customer Support who will be able to assist you further.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
