10-07-2017 10:12
10-07-2017 10:12
I set the running setting I want for my runs. Select the data fields, turn cues on etc. After each run, they reset to factory settings. Any way to save these settings?
10-18-2017 00:09
10-18-2017 00:09
Yep, mine too.
I want cues every mile, but it always resets to 1/2 mile. I’ve changed it on the Fitbit dashboard too, still does it.
Its annoying.
10-18-2017 05:22
10-18-2017 05:22
Yeah, I have the same issue.
Also, does anyone know exactly what the layout is for the lap alerts? I swear I keep seeing times that are faster than I'm running, but I don't want to stop long enough on a run to figure out exactly what the alert is showing/how it's laid out...
10-18-2017 05:43
10-18-2017 05:43
I'm confused by this too. Last night one of my 1 mile laps said "8:50". But once the run downloaded into the app, I didn't have any mile laps at 8:50.
I also noticed that if you just tap the gear icon before your run and then the back button, it applies the changes you made in the settings to the run. It's like the settings are not being applied when you just hit run without first selecting the settings.
Best Answer10-28-2017 23:42 - edited 10-28-2017 23:45
Hello, I am having the same issue and I am pleased to see I haven’t been imagining it. I did a marathon yesterday and was really disappointed as the battery went flat at the half marathon mark. Partly I think because it had gone back to factory settings. The energy saving tip of the screen staying on had defdulted and I had the half mile alerts I didn’t need. I am interested to know the battery life with the GPS on. Hopefully FitBit can provide a fix to remembering the settings.
Best Answer10-29-2017 05:57
10-29-2017 05:57
Oh my. I couldn’t imagine this watch lasting a full marathon. I’d be shocked if it lasted 10 miles!
Best Answer10-29-2017 06:36
10-29-2017 06:36
Best Answer10-29-2017 06:41
10-29-2017 06:41
Hello, thanks for the reply. I went into read on another post that the battery should last 10hrs with GPS on.
Yesterday I didn’t have the screen turned on all the time but I thought in the run settings it suggested you did, to save battery (not that i follow the logic). This had defaulted back to going on and off.
Best Answer10-29-2017 06:46 - edited 10-29-2017 07:08
@Brimy311 wrote:Oh my. I couldn’t imagine this watch lasting a full marathon. I’d be shocked if it lasted 10 miles!
I don't understand this statement; consider the following:
In total I logged 32.1 miles which consumed 5:40:35 of GPS time over a single charge which lasted 67 hours. I'm thinking even a 6-hour marathon competitor will easily be able to use an Ionic for the full event.
Edit:
Here are the supporting screen shots:
Activity summary:
Here is my Wednesday heart rate track; notice the ~1.5 hour gap in the track between 8:30 PM and 10:00 PM from when I charged my Ionic:
Here are the heart rate tracks from Thursday, Friday, and Saturday; as you can see, the next ~1.5 hour gap caused by recharging was Saturday afternoon between 3:30 PM and 5:00 PM:
Best Answer01-01-2018 04:16
01-01-2018 04:16
I have the same problem (set autocue for every mile but when I run it tracks every half mike). Very frustrating. It also seems that no one has a solution and the folks at Fitbit don’t have a clue (or appear to care that their product isn’t working properly) given the jack of response.
09-14-2018 06:44
09-14-2018 06:44
My ionic was working fine for months now every time I want to run I have to set the custom stats when will this be fixed please ?
