Ionic - Screen Wake auto-manual hybrid
I noticed the Screen Wake set in Automatic behaves differently now. Here are is what I see -
1. Screen Wake set to auto
2. Raise wrist to turn the screen on (you are trying to see the time)
3. Let screen go to sleep based on the timeout (not by putting the wrist down, which will force the screen to turn off)
4. Now single tap the screen - it will wake up
5. Now put the wrist back, which will force the screen off
6. Now single tap the screen - it will not wake up
It looks like when the wrist is in the "read" position, tapping the screen will turn it on regardless of Screen Wake set to Auto or Manual.
While I like it, I wish it ALWAYS woke up on screen tap. In a way working in both Auto and Manual modes at the same time! Or at least there should be a mode called "both" in Screen Wake setting for people like me!
Thoughts?
1 REPLY 1
I like it just fine the way it is.  If you like, you could post your suggestion in the Feature Suggestions Forum.
