10-02-2017 10:52 - last edited on 06-13-2018 15:02 by SantiR
I have had my ionic for a week tomorrow. Still have not been able to sync it properly and use it. I have talked to the customer service team multiple times and spent hours trying to trouble shoot with them.
It takes about 2 hours to get it set up. It syncs for about 5 minutes and then disconnects. It then goes back and forth from looking and syncing but never connects.
How long do we need to wait before this gets fixed or they can give some update. I have tried all the trouble shooting including factory reset, etc. Very frustraing.
Moderator Edit: Updated Subject for Clarity
12-16-2017 05:07
12-16-2017 05:07
12-16-2017 05:35
12-16-2017 05:35
I voted with my feet. Sent it back and got a refund. Absolutely pathetic that there isn’t a proper fix for the syncing issues yet.
I got an Apple Watch instead. It works with no issues......
12-16-2017 06:24
12-16-2017 06:24
12-19-2017 01:45
12-19-2017 01:45
Yes, the fitness part is great but the sync and wifi is **ahem**!! and it got even worse after the update. I am just lucky if it syncs once a day to my IPhone. How hard can it be to fix this???
12-20-2017 08:51
12-20-2017 08:51
I have sync problems with ionic (android)
But my problem isn't with the watch but with the ionic application that isn't able to find the watch. Once I restart the phone, the sync works correctly.
i have to restart the phone since the new version of the app. Before, the notifications were lost from time to time, but the app was not loosing the watch.
I have tried to remove the watch from the phone and paired again...
12-20-2017 09:08
12-20-2017 09:08
@AmyLouie @Nuah @LwrHrtRt @GekkoZZZ @Ralendil It's great to see you in the Fitbit forums, I hope you are all doing well! I moved your posts to this thread about syncing issues with Ionic to keep the Community organized.
Please follow these syncing troubleshooting steps. This should help you out with this. Let me know ig you keep experiencing the same afterwards!
Also, feel free to check the rest of the thread for more details and experiences.
See you around!
12-20-2017 10:26
12-20-2017 10:26
Hopefully the Sync will be fixed.
I have spent to much time on reading on Sync, restarting watch and phone, reinstall app, ...
I think the Sync was working before the upgrade (because I never had any issues any the sleeping was updated every morning)
So what is Sync and was does it? For me it seams like there are two kind of information that get Sync.
1. Fitness data on dashboard (steeps, floors, cal,....). This works perfect
2. Battery indication, sleep data and account changes e.g. exercise shortcuts
So why does not the second part work and how should it work?
I am able to Sync every thing to my Mac (must turn of BT of phone before I can do it) and the strange thing is that it looks like the Fit app on phone also get Sync then??
The phone also Sync everything when I delete the Ionic and add it again.
12-20-2017 18:07
12-20-2017 18:49
12-20-2017 18:49
@SantiR Thanks for all of your information and Carlos's post in another topic.
I have had a very successful run with the Fitbit Ionic since release day in Australia, 2-1/2 months.. Everything was working. No swimming or water use. Suddenly the other night the sleeping didn't record and any HR activity is missing including the RHR for the next day.
The Ionic is registering HR pulse, steps etc and is functioning normally each day as one would expect.
So after following the steps in the posts which included un-pairing the Ionic I cannot re-link the Ionic. Now it will never pair.. It just cycles around the 4 digit code and try again.
So to prove I don't have a phone problem I added my Blaze, Surge and the One and they are all working and syncing as expected in multi mode. That involved a software update for all three Fitbit models.. Again, worked perfectly and the Blaze recorded a perfect sleep cycle last night. The same day I had the failure I upgraded the App to V2.63.. After the Ionic failure I decide to delete the 2.63 App and load the 2.62.1 App. That made no difference. So now every Fitbit I have and the App are on the latest versions of firmware/software.
The Bluetooth on my Android won't even detect the Ionic, but when I attempt to add a device it finds and connects and the 4 Digit code and we keep cycling around that..
My environment hasn't changed and pairing my other Fitbits proves that all is working. Just now I walked away from where I'm typing this and the phone was next to me on the table. I was over 40' (13m) away and the notifications appeared on the Blaze.. So that part of Bluetooth is strong.
Another test and I have turn the Surge on... it hadn't been synced since 8pm last night and has synced perfectly and shows the same step count as the Blaze. Just did the same with thew On and a perfect step match.
I have posted this here because others may have a solution and parallel to this Fitbit Support are handling my case.. One of their suggestions was to use WiFi but in our communications they overlooked I cannot pair the Ionic.
Hoping there are some other suggestions, after over 300 successful Pay taps I have to resort to a physical card..
12-20-2017 19:31
12-20-2017 19:31
I have two Droid turbos (original, not turbo 2". I have followed the sync steps 100s of times. It will sync.... sometimes. When it doesn't sync, the issue is identical using either phone. When it does sync, it can sync on either phone.
Rebooting the device doesn't make a difference, it just syncs when it wants to, and stops for a day or so.
The problems we are having is the device itself. And the numerous step process that is provided does not passify the situation. I think the turbo should be taken off the compatibility list until, if ever, this is fixed in a future update.
12-20-2017 19:58
12-20-2017 19:58
@SunsetRunner I'm convinced it's not your phone and the same with me. I had issues when the Blaze first came out on my previous Sony phone and it had Android 6.1. My latest Sony, over a year old is on Android 7.1.1 and up until the other night has worked perfectly with all of my Fitbits. This phone is not on the compatibility list and probably not tested because its market position is a lot lower than the leaders.
I enjoy my Ionic and I'm sure Fitbit will come up with an answer.
12-21-2017 22:26
12-21-2017 22:26
12-22-2017 04:40
12-22-2017 04:40
I followed the advices and removed the always connected option (that is described as improving the connection)
I must says it improved things.
I have not connections problems in fitbit app
And for notifications, so far, i received all of them.
I cross fingers, but it seems to work
12-26-2017 10:49
12-26-2017 10:49
go to the site you suggested and tell me how your link tells me how to turn the device off. 2nd day of trying to use my new fitbit ionic.
12-26-2017 10:52
12-26-2017 10:52
Probably the best advice you could give is where to return it!!!!!!!!!
12-26-2017 10:54
12-26-2017 10:54
how do you turn off bluetooth on the ionic?
12-26-2017 11:49
12-26-2017 11:49
Bluetooth for sync'ing can't be turned off.
01-03-2018 17:17
01-03-2018 17:17
Same bluetooth connection issues as everyone else and it still appears to be totally random on when it will/will not sync. None of the fixes work including the one with the rain dance and throwing salt over your left shoulder. IF Fitbit would communicate this as a software/firmware issue that is being resolved I would gladly be patient and keep my ionic waiting for a fix. However, no acknowledgment of a known issue has been made. I am seriously concerned that this is a hardware issue with faulty bluetooth antenna. Many people need to operate within a stores return policy and can't take the risk of keeping a dud watch around. Has anyone out there tried to exchange their ionic at the store for a new one? Did this solve any issues? Seems like this would be an easy way to confirm if some of us got lemons.
01-03-2018 17:41
01-03-2018 17:41
01-03-2018 22:37
01-03-2018 22:37
For what it's worth, my ionic only syncs when I drive. It won't sync at home, in the office or anywhere else but in the middle of the freeway. I think the code is written to sync to the highway vs. information highway
