06-19-2018 15:16
06-19-2018 15:16
Since yesterday afternoon my Ionic has gradually become unusable.
- Yesterday it stopped syncing. I went through all of the guides on the site and reinstalled the app on my phone few times. I eventually got a partial sync last night and again once this morning.
- This morning I went for a run and noticed GPS crashed the watch when I tried to find a signal. After it restarted, I was able to get it to connect and complete a 3 mile run.
- Over lunch today I went for a second run but now GPS will not connect and crashes the watch every time after ~15 seconds (tried 10 times). Also, when it did come back up, I decided to track my run with the Strava app on my phone and my Ionic didn't record a single step over the 5 miles.
- When I returned, I restarted my watch again and charged it. It now counts steps again, however, if I try to start the GPS at all, it crashes and loses any steps that I had taken since the previous restart.
Not sure what to do at this point. Is there any sort of factory reset for the watch that might clear this up? I uninstalled the fitbit app and had my bluetooth forget the Ionic but it still is having the same issues so I don't think it can be attributed to my phone (Pixel 2).
Best Answer06-19-2018 15:35
06-19-2018 15:35
I had similar issues and a factory reset has so far been an improvement. You could try the following steps
Once you have done that you need to set up again as if it was a new device.
Instructions can be found here
https://help.fitbit.com/articles/en_US/Help_article/1873
Hope this helps.
Best Answer06-19-2018 15:55
06-19-2018 15:55
Thanks for the recommendation.So far, after the vibration in step 4, it started flashing the Fitbit logo. It's been doing so for about 15 minutes. Not sure how long this restart part takes. Will reply back with the results.
Best Answer06-19-2018 15:57
06-19-2018 15:57
Took me about 30 minutes in total
Best Answer06-19-2018 18:21
06-19-2018 18:21
Just following up - it's been flashing for about 2.5 hours now. Is it possible to hard reset it again or do you think I should wait a few more hours?
Best Answer06-19-2018 22:43
06-19-2018 22:43
Did a factory reset again at about the 4 hours mark and waited another 2 hours now. It looks like it's stuck on the fitbit logo flashing. Will let it site overnight and probably have to contact customer support in the morning.
