12-17-2018
14:20
07:27
SantiR
12-17-2018
14:20
07:27
SantiR
Is anyone else with the Fitbit OS 3.0 update able to get water added on the ionic via the today app to sync with the dashboard? i can add all the water I want on the ionic, but it never syncs. Water I add via the dashboard shows on the ionic, but not the other way around.
Moderator Edit: Updated Subject for Clarity
01-06-2019
13:26
05:31
SilviaFitbit
01-06-2019
13:26
05:31
SilviaFitbit
I have an Ionic, updated to the latest firmware. When I try to track my water intake through the watch, it shows on the watch, but not on the Android app. Even if I manually enter data on the app, only that shows, ignoring previous data from the day ever on the watch. However, opening the web dashboard then shows the correct data, and then if I open the app, click on the water widget, and then on today's history, it will populate. I can also go back and tap on previous days that show 0 and they will then populate.
Best Answer01-07-2019 05:31
01-07-2019 05:31
It's great to see you on the Community @Bgg1! Thanks for the letting me know that if you check the Dashboard, you're able to see the correct information.
I would like you to manually sync your Ionic by opening the app > tap on the device's icon > tap on sync now. After this, force quit the Fitbit app.
Hope this helps.
Best Answer01-08-2019 16:24
01-08-2019 16:24
While this works, it's just rehashing what I said. The problem still exists that I have to manually sync numerous times as well as force close the app to get the data to sync. Seems like a bug to me.
Best Answer01-09-2019 17:26
01-09-2019 17:26
When logging water I take on my ionic, it is suppose to since to my dashboard on the phone.?
Best Answer01-09-2019 19:38
01-09-2019 19:38
Same problem here! Water logged in the water tile under Fitbit Today on my ionic doesn't seem to synch to the app on my phone...
01-10-2019 03:05
01-10-2019 03:05
Just thought I'd add that my weight has never been synced since installing OS 3 to my Ionic in December. I've added numerous ones via the watch to test but nothing's ever appeared on the phone (Android Xperia XZ1). Done multiple reboots of both but nothing ever appears to get logged. Disappears off the Ionic Today screen after about a week too?
Best Answer01-10-2019 06:22
01-10-2019 06:22
Yes, the weight feature has the same issue as the water. The workaround is the same too. You just have to log out of the app, and log back in.
Best Answer01-10-2019 16:58
01-10-2019 16:58
Thanks to everyone who took the time to report this issue!
Our team is still working on a fix for this. However, a potential workaround is to simply manually sync your Ionic and then force quit the Fitbit app. This should get your logged water to sync over.
I will be sure to keep you all updated as more information becomes available. Feel free to let me know if you have any questions.
Want to get more deep sleep? Join the discussion on our Sleep better forum.
Best Answer01-12-2019 10:16
01-12-2019 10:16
Doing as suggested to force close the app has caused by extra 'stats' in the Today App on my phone to disappear, they aren't even in the settings on the app anymore to get them back!
21:01
14:37
SantiR
01-15-2019
21:01
14:37
SantiR
I logged water intake directly onto my watch but my phone shows I drank no water today. (Just got a brand new replacement ionic). I have never logged water directly onto my watch before, so does that not sync back to my phone app?
Best Answer01-16-2019 11:59
01-16-2019 11:59
Hi @jst1986, thanks for reporting this. As mentioned before, our team is working on solving this, thank you for your patience while we're solving this out.
Keep us posted on what else you're facing with your Ionic and Fitbit App, your feedback is greatly appreciated.
Thanks!
01-16-2019 14:36
01-16-2019 14:36
@MMD247 Welcome to the Fitbit forums! Thanks for reporting the situation you are experiencing with the water logs not transferring from Ionic to the Fitbit dashboard.
This is something that is currently being checked by the Fitbit team to get a fix. In the meantime, a potential workaround is to simply manually sync your Ionic and then force quit the Fitbit app. This should get your logged water to sync over.
Hope this helps. Keep me posted! ![]()
Best Answer01-17-2019 14:51
01-17-2019 14:51
Mine had been doing ok syncing water so long as I periodically log out of the app, but since the latest update now I am having to restart the ionic.
Best Answer01-21-2019 19:15
01-21-2019 19:15
AndS problem with my ionic. I did as suggested. Still water not syncing. All other data is syncing normally.
Help please
01-22-2019 13:53 - edited 01-22-2019 13:54
Hello everyone,
Ive been experiencing this for about three weeks now. The water logged from my wrist shows that it has been recorded. However, it does not show up on my dashboard or total on my wrist. Any help would be greatly appreciate.
Please know that I have forced synced and forced close and still to no avail it has not synced since the beginning of the year. Please help me.
01-22-2019 16:10
01-22-2019 16:10
Hi all! Thank for your continued patience as our team works to resolve this waterlogging issue.
For iOS users, a potential workaround is to simply manually sync your Ionic and then force quit the Fitbit app. This workaround may not resolve this issue for Android users.
I will be sure to keep you all updated as more information becomes available. Thanks again for your patience!
01-23-2019 00:46
01-23-2019 00:46
It might be that you are being affected by a known bug in the software that was recently upgraded for the Ionic and Versa. Keep an eye on the following thread that has updates from fitbit:
https://community.fitbit.com/t5/Versa/New-Water-Log-not-Syncing-amp-Other-Qs/td-p/3127824
01-29-2019 01:12
01-29-2019 01:12
Water consumption added to the ionic won't sync with the app also, although it seems to sync the other way around. Ionic firmware version 27.33.1.30. Android app version 2.86.
02-11-2019 02:45
02-11-2019 02:45
Received a new (replacement) Ionic last week. My last Ionic seemed to sync water sporadically, but I can't get this one to at all. Android.
02-11-2019 18:26
02-11-2019 18:26
@jivanmsr @Romengaccord Thanks for visiting the Fitbit Community. Our team is working to get this waterlogging issue as soon as possible. Thank you for your patience in the meantime.
As mentioned above, you can manually sync your Ionic and then force quit the Fitbit app to get the water synced over.
Hope to have good news as soon as possible.
