10-17-2018 15:16
10-17-2018 15:16
Backlight is set to manual, comes on with 2 taps. Sometimes does come on for unknown reason.
Delay is set to 10 seconds.
After taps and backlight is on, never goes off automatically as it should.
Best Answer11-13-2018 17:20
11-13-2018 17:20
I reinstalled your app and it works now as you say. I can get between 3 and 4 days before the battery is flat.
It may be related to initial settings, some install glitch out of sync with fitbit settings themselves or just gremlins I have now eradicated.
Regardless I am now enjoying your clock face.
Thank you
Best Answer10-18-2018 00:19
10-18-2018 00:19
Restart your Ionic several times. If it still wont shut the display automatically try a factory reset (settings app onbthe watch and scroll down to About). If that doesnt fix it you need to contact Support (link in my signature)
Helen | Western Australia
10-25-2018 04:41
10-25-2018 04:41
I was using the clock face “Emergency Responders”. I changed to analog “Classic” by Julian. Now after 36 hours I still have 87% battery left, the backlight doesn’t come on unexpectedly and when I do tap to bring it on, it goes off at the setting 10 second delay. All good now.
I will I’ll send a note to the Responders app writer of the problems.
11-13-2018 17:20
Thank you
