03-04-2019 20:38
03-04-2019 20:38
Since yesterday my Fitbit Ionic's battery has been draining. It was on 100% in the morning and 15% by the evening (I did 2500 steps yesterday). Also it has stopped showing my heart rate.
I charged it again it was 100 % when I put it on this morning and after an hour I'm already on 89%. Still no heart rate data. I have restarted the watch 4 times and nothing seems to work.
03-05-2019 09:44
03-05-2019 09:44
Nice to see you around @R0sakn! Thanks for already troubleshooting this inconvenience, nice way to go! ![]()
One day of charge is not normal. In this case I'd suggest to try the tips on how to clean your Ionic battery to make sure that it is charging in a correct way. You will see the steps here: Why isn't my battery charging on my Fitbit device?
In regards to the tracker itself, keep in mind that the length of time your Fitbit device operates on a full charge depends on how frequently you use it and various settings.
Consider these tips when you want to conserve battery life:
it might be that the issues with the heart rate is related to the one with the battery, but if you keep having same issues after it starts lasting more time with a full charge; you can troubleshoot your Fitbit HR with these steps: Why don't I see my heart rate on my Fitbit device?
Give this a go and let us know the outcome!
Best Answer03-06-2019 01:24
03-06-2019 01:24
Hi
I have been using the Ionic for a good few months, get on average 4 days battery. All of a sudden, with doing no changes the battery just drained in a day and keeps doing it (day 3 now). Also, the heart rate started to show again but was completely out.
I have now done a factory reset and the watch wont turn back on.
I am not happy about paying so much money and the device malfunctions after a few short months. I will contact Fitbit support and see what they say.
03-06-2019 07:42
03-06-2019 07:42
Hi @R0sakn, thanks for getting back and for trying those steps. Sorry to see that it is not solving the issue. I've noticed that you already have an open case with our Support Team. Please try to let them know the details of the steps that you followed so they can keep assisting you.
If you have questions about anything else, I'll be around.
Best Answer03-07-2019 03:20
03-07-2019 03:20
Hello
Yes, I have opened a case. The fitbit wont start at all, seems to be caught in some kind of reboot loop (not sure). There is nothing I can do but wait until they reply to me.
Thank you for your help.
