11-01-2020
14:01
21:36
RicardoFitbit
11-01-2020
14:01
21:36
RicardoFitbit
Since the last update, my battery only lasts 24 hrs, before it was 3 to 4 days. Has anyone else experienced this problem? How did you fix?
Best Answer11-01-2020 14:43 - edited 11-01-2020 14:44
PLENTY of discussion in recent archived posts - have you searched the forum?
Not a simple fix unfortunately.
You could try a few things;
restart your Ionic
Unpair/repair it to your phone
Factory reset the Ionic - after unpairing/deleting from your phone
Wait for a future fw release from Fitbit, that has hopefully addressed the issue.
11-01-2020
21:36
06:09
11-01-2020
21:36
06:09
Hi @Miffy24, welcome to the Community Forums!
Thanks for bringing this to my attention. Let me share with you that the battery of our Ionic was designed to last 5 days, but this also depends on how frequently you use all the features of your device. That said, I recommend you charging your Fitbit device with a USB port from a computer or a UL-certified outlet into the wall and then turn off all the features that you don’t use that much.
After following the above information, please check this help article for more tips and recommendations. This article includes as restart process that will refresh the device's performance.
@PaulMe Thanks for your help!
Let me know if further assistance is needed and if you have any additional questions.
