09-20-2021 22:31
09-20-2021 22:31
I've always had 5+ days of battery life on my Ionic. Don't know if it was a recent firmware update or what but in the past few weeks it's gone from 5+ days of charge to less than 2 days, and now this week, less than 24 hours. I tired a factory reset, almost seems worse now. Can't do a workout without the battery dying. So much for logging my workouts. Very frustrating.
09-21-2021 07:50
09-21-2021 07:50
@riddled Welcome to the Community.
Sorry to hear about this and thank you for troubleshooting this issue. Please try these suggestions to improve your Ionic's battery life.
Hope this helps.
09-23-2021 00:32
09-23-2021 00:32
Agree mine has went from lasting a week to not even 24 hours. Now constantly running out of battery, iv not changed any settings. Tried the factory reset but as you say think it’s worse🤬 come on Fitbit
09-23-2021 07:58
09-23-2021 07:58
@Craigw80 I hope you're doing well.
Sorry to hear about this. Please try the suggestions in my previous post to see if this helps improve the battery life on your device.
See you around.
09-29-2021 18:24
09-29-2021 18:24
I have been dealing with this issue also since my ionic was last updated. I have disabled auto screen, all notifications, all vibration, and am using a very basic watch face. I tried a factory reset with no luck. My device is less than a year old. I am convinced something was changed in the last update, as I used to get up to 7 days between charges before the update, and now it is less than 24 hours. Please fix this.
09-29-2021 18:37
09-29-2021 18:37
I did much the same with no luck. I've talked to a few other Ionic users who have the same issue all since the last firmware update. I've ordered a new battery to see if it helps. I'll report back the results.
09-29-2021 18:39
09-29-2021 18:39
I've followed your suggestion with marginal success. I've gained minutes, not days (not even hours). I've ordered an new battery and I'm going to attempt a battery replacement. But this sure seems related to the last firmware update. Hard to believe my battery died the same day as the patch was pushed.
09-30-2021 02:16
09-30-2021 04:40
09-30-2021 04:40
This affects me too. Went from 7-day charges to dying overnight on a full charge. What's going on with Fitbit? Get this fixed even if you have to roll back that last update.
10-21-2021 14:25
10-21-2021 14:25
Yes tried all the suggestions but no luck, contacted support team who could see remotely the way was needing charged daily. Was offered 35% of a new Fitbit however I am annoyed I spent a good amount of money on the ionic expected it to last far longer! I won’t be investing in another Fitbit if they only last a few years! Very disappointed
10-21-2021 16:02
10-21-2021 16:02
Tried everything. My Ionic after the update went from 5-6 days to less than 12 hours. Fitbit needs to do a rollback on this last update. After 10 years of Fitbits only lasting 2-3 years, it is time to research alternatives. Love the FB but I am done with always replacing after only a few years. Way too expensive to not last. WTF
11-01-2021 07:18
11-01-2021 07:18
I am having the same issue. Using original clock face and done nothing different but I am having same issue less than 2 days charge now. How can it suddenly change.
11-01-2021
07:31
06:12
11-01-2021
07:31
06:12
Hi @REDSHELL1977 - as mentioned by @catu-ualos - what changed was the firmware update.
Are you on firmware 27.72.1.15 ?
11-01-2021 08:13
11-01-2021 08:13
11-05-2021 09:42
11-05-2021 09:42
Same problem, tried everything, but nothing works. Less than 1 day is not enough for me. I hope that the problem will resolved on short notice!!
11-05-2021
19:10
06:13
11-05-2021
19:10
06:13
Hi everybody!
Thank you for sharing your comments and for checking if your Ionic is running the latest update to improve battery life. If you've already tried the steps suggested here: Can I extend my Fitbit device's battery life? and Why isn't my Fitbit device's battery charging?
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
