06-13-2018
18:04
05:51
06-13-2018
18:04
05:51
I have had my ionic since October. I have been getting seemingly 4 to 6 days without charging. Now with all of the updates i have to charge every other day. Is this a device problem or new firmware problem?
06-26-2019 12:01
07-25-2019 07:15
07-25-2019 07:15
Yes I am facing the same problem.
Battery drains out within 2 days
07-25-2019 07:18
07-25-2019 07:18
Hello Marre,
With no change in the settings my IONIC was lasting almost 7 days.
But since the last update it is draining within 2 days.
Is there any glitch in new update / firmware?
\Can you please let me know how to delete the new update and go back to the older one?
Best Answer08-02-2019 10:13
08-02-2019 10:13
same issue. my ionic charge was lasting 4-5 days, now suddenly its bare 12 hrs!! I have made no changes in use to my knowldge!!
08-02-2019 18:52
08-02-2019 18:52
Hi, Hold the left button in till the Fitbit vibrates then you will be able to adjust your screen wake and ur notification settings 👍🙂
Best Answer09-06-2019 07:12 - edited 09-06-2019 07:16
I'm having this problem too, since about June. I did a hard reset which made it slightly better, but it still drains in less than a day. It has rendered the watch practically unusable. Is there a fix?
Edit- I got the watch new at Christmas 2018, so it's lasted all of 6 months.
Best Answer11-22-2019 04:29
11-22-2019 04:29
Hi, i have almost the same problem, normalybi was charged my Fitbit Ionic max 2 time a week but i dont know whats going none. The battery works max 2 days. From this two days take 25% for a full day and next 25% for a night. Sometime i have to charging in second day in the morning cuz i have 11%. Last time i didnt use GPS and i didnt make workout... sooo i dont know whats is wrong.... maybe i schould call support?
Best Answer11-22-2019 05:02 - edited 11-22-2019 05:03
Hi, I sold my fitbit and bought Garmin Vivoactive HR.
I charge battery every 10-14 days!
I am happy now.
Regards.
Best Answer11-22-2019 06:03
11-22-2019 06:03
Best Answer11-24-2019 20:22
11-24-2019 20:22
I did not start having issues with battery life until the latest update. It is unbelievable that the suggested fix is to turn everything off. I was able to use all these features prior to the update without draining the battery. Why have a fitbit if you have to constantly turn on/off the various features. I’m very disappointed with this product and Fitbit’s responses. There are plenty other products on the market...I expected better from Fitbit 🙁
11-24-2019 20:26
11-24-2019 20:26
Fitbit support was useless for me. They told me to turn all features off.
11-24-2019 20:26
11-24-2019 20:26
I may look into doing the same.
11-25-2019 04:00
11-25-2019 04:00
01-06-2020 05:03
01-06-2020 05:03
I have trouble getting 8 hrs out of mine as of late!! Is it a device/battery/software issue or is it just time for a new one even though mine is only a couple of years old.
02-10-2020 12:10
02-10-2020 12:10
same issue
I've noticed a significantly less battery duration pre to post update, while using Ionic the same way
02-10-2020 13:00
02-10-2020 13:00
We are in 2020. And fitbit do not care...
Fitbit bought pebble. Google bought fitbit.
Maybe a "Rebble" app for fitbit will be made and make our watches work good. Who knows.
Best Answer02-10-2020 16:38
02-10-2020 16:38
So true. I think the complaint goes to trash cans. They just don’t care.
I’d say look for alternates that stand behind their Software quality better than FitBit/Google!!
Best Answer02-10-2020 20:11
02-10-2020 20:11
Best Answer04-18-2020 06:33
04-18-2020 06:33
Add me to the list. I've stopped using it.
Best Answer04-20-2020 07:53
04-20-2020 07:53
My Garmin works well. I gave up on Fitbit two months ago. I am sad about that, because the Fitbit user interface was far nicer, and a few years ago the company was great. No longer. At least Garmin stands behind their product and doesn't ignore thousands of complaints and refuse to fix the firmware.
