10-05-2017
06:23
13:53
MaginB
10-05-2017
06:23
13:53
MaginB
I have had my Ionic for less than a week and I bricked it. I was headed down to the gym to log my 3rd workout with this device. I was going to listen to my headphone connected to my iphone to mitigate the gym grind but that is where the fail happened. I put my Soundbud slims in my ear and powered them on and received the audible bluetooth connection. I press play on my iphone and the sound came out of the phone, not my headphones. I looked down and my Ionic no longer functioned. I've tried hard reset, plugging it back into the the charger, the computer but still only get a black screen. My only guess is that somehow my headphones paired with my Ionic which caused the brick. Has anyone else had a similar experience?
Best AnswerHi
Thanks for visiting the Forums @rockstarsalvo!
I totally understand your frustration to this matter. The Support Team is aware of this inconvenience and are currently working to have it solved as soon as possible, your patience is gladly appreciated.
@SunsetRunner Thanks for your help!
See you around!
Best AnswerI think the title change is more confusing. I was not trying to pair my headphones to the Ionic. I simply powered the headphones on an expected them to sync with already paired iPhone to play my music. The Ionic’s role was just to log my workout.
Do you think you can explain what happened? It sounds like you connected your headphones to your phone. How was the Ionic involved.
@MaginB, what should we recommend people do about the issue?
Best AnswerI had the same problem, twice now.
@rockstarsalvowrote:I have had my Ionic for less than a week and I bricked it. I was headed down to the gym to log my 3rd workout with this device. I was going to listen to my headphone connected to my iphone to mitigate the gym grind but that is where the fail happened. I put my Soundbud slims in my ear and powered them on and received the audible bluetooth connection. I press play on my iphone and the sound came out of the phone, not my headphones. I looked down and my Ionic no longer functioned. I've tried hard reset, plugging it back into the the charger, the computer but still only get a black screen. My only guess is that somehow my headphones paired with my Ionic which caused the brick. Has anyone else had a similar experience?
