11-17-2018 20:46 - edited 11-17-2018 20:47
My ionic used to track sleep stages just fine up till a few weeks back.
Since past two weeks it is not able to read my heart rate consistently for sleep tracking. Hence showing simplified sleep tracking.
I tried cleaning heart rate sensor, removing and installing app again, changing the hand. Even adjusted the strap to fit it little tight. Nothing is helping.
I searched and found a lot of users are having the same issue. This can not be a misfit on my wrist that is causing this. There must be an app update which caused this.
Best Answer11-18-2018 00:59
11-18-2018 00:59
Have you tried restarting your Ionic? If that doesn't work you could always try a full factory reset, you have nothing to lose at this point and that should rule out any software issues.
Best Answer11-21-2018 22:54
11-21-2018 22:54
Tried restarting the device. Even did the system reset. The sleep tracking worked for one day. Back to simplified tracking.
This is exactly how I used to wear my watch before and sleep tracking worked just fine. There is something wrong in either watch or the software.
Best Answer11-23-2018 16:08
11-23-2018 16:08
How to ask for Fitbit's infor on this?
I got the same issue then i reset but now i cant even pair my phone with ionic .
So frustrated 😞 since this bought second hand from a known-runner
Best Answer11-23-2018 16:10
11-23-2018 16:10
How to ask for Fitbit information on this?
I got the same issue then i reset but now i can't even pair my phone with ionic .
So frustrated 😞 since this bought second hand from a known runner
