09-19-2018 15:25
09-19-2018 15:25
I have purchased the ionic and its NOT compatible with my phone, which is the Samsung galaxy j7sky pro. However, it's compatible with some 2014 versions. Very frustrating.
I've been with Fitbit for a few years but this issue has made me seriously contemplate transitioning to the iPhone and Apple watch.
09-19-2018 20:38
09-19-2018 20:38
It takes time to test phones they come out with new ones all the time.
You really should check the compatible phone list before buying
https://www.fitbit.com/devices
Wendy | CA | Moto G6 Android
09-20-2018 01:06
09-20-2018 01:06
None of my phones are on the 'compatible list' which hasn't been updated for four years for most phones.
It's quite nostalgic to read through the list 🙂
There is no Android phone that shouldn't work fully.
However this may need a little trial an error and you will probably find the work around on the Phones forum rather than on here.
You only need to look at the threads to see most connections come down to workarounds and trail and error anyway.
Good luck!
Best Answer01-10-2019 14:58
01-10-2019 14:58
I just purchased an ionic and just found out that it's not compatible with my Samsung Note 8. I find this completely unacceptable since my Blaze was fully compatible with my Samsung Note 8. Fitbit should make it very clear to customers before they make a purchase which phones are not compatible with the ionic. It's an the.
01-11-2019 04:24
01-11-2019 04:24
01-11-2019 08:25
01-11-2019 08:25
01-29-2019 20:25
01-29-2019 20:25
I have a phone, tablet, mini iPad and macbook none are compatible. On the verge of ridiculous. They where all compatible with the Blaze. Maybe keep a product till you get a compatible operating system on your new watches.
Best Answer01-30-2019 02:54
01-30-2019 02:54
01-30-2019 06:22
01-30-2019 06:22
Sorry I meant FitBit should not put out new products until they are compatible. I also had the Blaze and loved it,
Best Answer01-30-2019 07:01
01-30-2019 07:01
Best Answer02-20-2019 15:23
02-20-2019 15:23
Wish I had read your post a month ago.
