Ionic connection with my phone flaky after phone reset.
I recently reset my Android phone and ever since I have had trouble connecting my phone to my Ionic.
It does connect after I keep tapping on sync repeatedly but it isn't able to hold the connection for recieving notifications.
Can someone please tell me what I should do? Should I remove the device from my app and add it again?
5 REPLIES 5
Have you tried restarting your phone?
or restarting your Fitbit?
https://help.fitbit.com/articles/en_US/Help_article/1186
If both fail, uninstall the Fitbit app then re-install.
Let us know how that works for you.
So I tried all of the following:
  • Restarting my phone.
  • Restarting my fitbit.
  • Reinstalling the app on my phone.
None of these have been able to restore my Fitbit sync with my phone. I am currently syncing it through the laptop.
Are there any more measures I can try?
Having same problem with mine and iPhone still no luck as well
Have you tried to remove the Ionic from the app, do a factory reset and add it as a new Ionic?
I have a feeling that that might work. So I just wanted to check if you've already done it!
Tried this several times. Only stays connected to phone for few seconds then drops out. I get PIN number to connect then drops out before I get chance to connect. Then 30 seconds later get new pin just over and over and over
Sent from my iPhone
