04-27-2018
20:59
11:52
RicardoFitbit
04-27-2018
20:59
11:52
RicardoFitbit
My Fitbit Ionic has water inside it. It started acting funny while I was in the shower. It has obvious signs of water on the front screen, which touch is not responding anymore. Was able to sync and it said I walked over 7,000 floors! You can obviously see condensation behind the sensors. Of course I can’t find the receipt and I’ve only had the watch for about three months! Please help!
04-28-2018 06:07
04-28-2018 06:07
You really need to contact Support. Even if you dry it out successfully (in rice) it is obviously not waterproof, so needs replacing. Support link in my signature
Helen | Western Australia
04-30-2018 20:45
04-30-2018 20:45
You need to contact fitbit for a replacement. My ionic screen fall out and got water in it, I had to call fitbit for a replacement.
01-24-2019 09:09 - edited 01-24-2019 09:17
Same issue here and they can't send a replacement to my country, I am truly sorry for wasting money on this company. They advertise their product as being waterproof but it took one shower to break the device. I really don't recommend buying Fitbit Ionic.
02-20-2019 06:44
02-20-2019 06:44
Yesterday I went swimming at our local leisure centre, at first i thought my battery had died. I went home an put my ionic on charge, nothing happened! I looked at my watch an discovered condensation on the sensors. I immediately contacted Amazon where I purchased my ionic from. Amazon patched me through to fitbit but oddly instructed me to stay on the line after my call with fitbit? I was still well within my warranty an took out insurance on the watch also. Fitbit asked me to send photos an information via email an they would come to a decision on what they would do. After my call with fitbit the gentleman from Amazon strongly disagrees with how fit bit handled the call, as he was on the line listening?? an instructed me to ignore there email an he would send me out a replacement for first thing the next day. Sure enough my replacement watch arrived the next morning. Apparently due to me been a prime customer the matter was delt with immediate. Found it extremely odd how the gentleman from Amazon stayed on the line through my call. Any thoughts?
03-04-2019 06:12
03-04-2019 06:12
This was my response to the hugely flawed ionic in a survey after a denied warranty replacement...Not necessarily Dorys’ fault, but I have had a lengthy warranty process with my ionic. Most of the time it has been broke or in the process of warranty. I understand you go by date but if I’ve received a New Ionic every time it should last longer then it has. One face and guts fell out, one wouldn’t charge suddenly, now this one has visible condensation and will no longer turn on. Kinda frustrating, I definitely don’t have the money to put towards another watch because my kids are expensive. Maybe you should remove how durable and waterproof it is so it’ll last or get rid of it. Sounds like a headache on both ends.
01-09-2020 06:07
01-09-2020 06:07
This happened to me too.
01-09-2020 06:10
01-09-2020 06:10
I'd be so glad if I had that kind of customer service. FitBit has terrible customer service/support!
01-09-2020 06:12
01-09-2020 06:12
And the funny thing is that Fitbit, because I bought it directly from them online, refused to ever give me a receipt of any kind.
08-02-2020 12:32
08-02-2020 12:32
Mine has also stopped working with signs of water inside. Can Fitbit help repair/ replace? It must be a defective seal. 2/8/20
08-02-2020 19:19 - edited 08-02-2020 19:20
See reply in your original thread.
https://community.fitbit.com/t5/Ionic/Ionic-water-damage/m-p/4400595#M134601
08-04-2020 01:02
08-04-2020 01:02
how do i contact support, the same just happened to me.
I bought my ionic 2 years ago in my home country. I am in Germany now and i did not bring the box/warranty etc D :
Do i have any option or just give up on it and get a garmin now?
08-04-2020 01:10
08-04-2020 01:10
Device only comes with a 1 year warranty. Unless you want the 25% discount on the full price, you may as well move on.
Official line is the device is fine for swimming/water sports. We know better though.
08-04-2020 01:16
08-04-2020 01:16
Yeah... thanks for the reply..now i would not buy the same watch even with discount....i dont want it to be damaged again in the pool ;/ (i dont shower with it)
11-18-2020 09:26
11-18-2020 09:26
Hi, I had same problem. Now My Fitbit stop count the steps and HR. Did the sensors died now ?
I wanna open this and fix it, is this possible ?
11-18-2020 13:49 - edited 11-18-2020 13:50
Not really. You CAN crack open the back but It'll never be the same again. Search Google/you tube for details. If it's a throwaway, then I guess you could muck around trying - but the waterproof integrity will be worse than before if you can get it back together.
Some with too much time on their hands have changed the batteries in Ionics/Versas.
11-18-2020 21:03
11-18-2020 21:03
Thank for your comment.
But I still wanna try do u know how to find a defective Fitbit ionic ?
My Fitbit looks like fashion watch right now so I want to open it to discover what happen.
11-20-2020 21:44
11-20-2020 21:44
My ionic also died today just after 5 mins in water. Never thought it would end this way. I just had mine a little over an year, any luck with fitbit support?
11-21-2020 00:06
11-21-2020 00:06
Never had any luck with support..... didn’t even offer to fox & I pay for it, only offered buy a new one with 5% off!!! Shocking
02-05-2021 12:42
02-05-2021 12:42
Happened to mine as well. I never swim or shower with it, I just rinse it under the tap after running. Condensation has evaporated but the panel with the sensors has expanded, look at the edge of the panel in the attached photo.Condensation gone, panel swollen
