04-20-2019
23:52
09:46
YojanaFitbit
04-20-2019
23:52
09:46
YojanaFitbit
Hi all.
Ive had a number of fitbits over the years and loved the GPS function on the Surge when played football (Soccer for my USA counterparts).
Ive had an Ionic for about 7 months or so and now its totally dead. My blaze before that lasted 9 months and then broke. I had 2 or 3 surges over a 2 year straight.
Do you all have issues with fitbit or is it just me?
With my ionic I have reset the watch done all the hardware boot thing you need to try (hold the 3 buttons let go wait and stuff) but nothing works.
How many other uses out there have issues with fitbit? Do fitbit have a short shelf life or do i have the worst luck ever??
04-21-2019 09:30 - edited 04-21-2019 09:50
Nice to see that you're digging into the Forums @oldskoolsandhu, let me give you a warm welcome to our Community.
Thanks for reaching out to share your feedback. I can see that you really like Fitbit products, we appreciate your loyalty over the years. About the issues that you've had with your previous devices, we might have to check with our support team to see if they have more details about what happened with them. I can request a case for you, if you need so.
In regards to the issues with your Ionic, I really appreciate the time you've taken in order to troubleshoot it. Thanks for trying to restart it. But since this didn't work, I'd recommend to check the following information:
Please let me know if your need more help. I'll be around.
04-22-2019 05:33
04-22-2019 05:33
Hey Yojana.
Thanks for your message,
Few points to answer below
Always keep the tracker clean and contacts are dirt free
Normally use my laptop to charge, and checking my USB plug a home and its a 1amp output
I have just tried a full reset again and used 2 devices to try pair the tracker.
It is a pain
