02-19-2019 05:56
02-19-2019 05:56
I’ve had it since June and use it abit for cycling at the gym. The other day it died in the middle of the day with 50% charge and now won’t turn on again even when plugged in. Entirely non responsive. Emailed customer support 4 days ago but still no response. Any help out there?
02-21-2019 09:58
02-21-2019 09:58
A warm welcome to the Community @Simonsinger. I appreciate the details that you've mentioned as well for letting me know that you've contacted our Support team. I've double checked your case with them and they've mentioned that it's been already resolved.
Best Answer04-15-2020 06:40
04-15-2020 06:40
This is the same problem I have, I went to bed with the ionic on and about 70% charge. Woke up and its dead. No response when charging. Tried to reset using the left hand button and the bottom right hand button and still nothing at all.
04-15-2020 13:27
04-15-2020 13:27
04-15-2020 13:42
04-15-2020 13:42
Try and hold down all 3 buttons for up to 30 seconds to see if that restarts it.
Best Answer04-15-2020 13:45
04-15-2020 13:45
Best Answer04-15-2020 13:57
04-15-2020 13:57
Mybit was going 5-7 days without charging. Got the new OS, and it started needing charging every third day, and then every other day. This morning it was dead, yesterday it had 80%. Something with the new OS is killing these Ionic watches.
Best Answer04-15-2020 13:58
04-15-2020 13:58
04-15-2020 16:36
04-15-2020 16:36
This is what they told me and it worked for me:
it took almost all 30 seconds for it to come back on, so time it.
04-15-2020 20:10
04-15-2020 20:10
Same issue encountered. Tried your method and it works. Thank God!
Best Answer04-16-2020 08:43
04-16-2020 08:43
Best Answer04-16-2020 09:32
04-16-2020 09:32
04-16-2020 22:53
04-16-2020 22:53
My ionic has the same problem it went to black and will not turn on. The only thing it does is the Fitbit logo shows up when you plug it in and thats it. It doesn't matter if I hold the left and bottom right buttons down or if I hold all three it just the Fitbit logo. I even left it for a couple weeks dead and tried it again. Nothing, is there some kid of fix if not its to bad because with he numbers of issues you have had with all your products I have purchased you have lost costumer since 2014
Best Answer04-17-2020 05:29
04-17-2020 05:29
Thank you Garmin Fenix, I will look at one of those as an alternative.
Best Answer04-17-2020 05:30
04-17-2020 05:30
My sympathies. Same happened me today, Ionic dead and unresponsive. I have been with Fitbit from Fitbit one (which worked fine) Charge 2 (was okay) Aria Scales (very buggy and hit and miss in synching, not accurate, got a replacement on warranty but not much better still buggy) and Fitbit Blaze (battery life tanked just out of warranty) and now an Ionic which has charging problems (unresolved) and today black screen of death on the Ionic. I am bitterly disappointed and think it is a shame on me that I continued to buy Fitbit. Time to save money and frustration and move to another brand.
Best Answer04-17-2020 06:24
04-17-2020 06:24
06-17-2020 12:04
06-17-2020 12:04
Thank you Timbo, I need to follow your lead and switch to Garmin. Fitbit is a constant source of disappointment and unreliability.
