Ionic exercise mode?
ANSWERED
when I first got my Ionic (which I really like), the lower right button brought up my first exercise SHORTCUT (which is what I wanted).  This morning, that behavior seems to have changed.  That same button now brings up the list of COACHING sessions (Treasure Chest, etc).  I don’t think I’ve changed any setting to do this, but clearly I have.  Can someone help me switch it back?
thanks in advance.
Steve
1 BEST ANSWER
Accepted Solutions
Hi, @SteveIonic, the right button will activate the exercise app as long as you have not rearranged the apps.  If they are rearranged it will activate whatever is in the first column.
If you have accidentally rearranged them, putting them back in the original order (Today top left, Exercise bottom left) should return the button to expected behaviour.
To rearrange the apps touch and hold the app on the screen and then move them as you like.
I hope this helps!
5 REPLIES 5
Hi @SteveIonic - You are correct - the right lower button should trigger the exercise mode. I am not aware of anyway to change that. Can you please try restarting your ionic?
http://help.fitbit.com/articles/en_US/Help_article/1186
Let us know if that doesn't help.
Hi Ozzie.  Thanks for your response.
I tried restarting the device, but I’m still seeing the list of coaching workouts instead of the exercise mode.
Thanks in advance for any any additional ideas or help.
I hope this helps!
I just played around with this. Yes the lower button brings up what is in the lower left on the screen to the right. The upper button bring up the upper left app.
Thanks!   Rearranging the icons did the trick. I appreciate the help!
