10-10-2019 00:42
10-10-2019 00:42
Help how do I log the problem with my fitbit. It is my lifeline as I have cochlear implants. Deaf when they are off. Because it vibrates it is my alarm clock ,my message minder , my daily move assistant and my time to take a break warning. It wont start at all so i cant get it to continue the update
10-10-2019 01:11
10-10-2019 01:11
Have you tried the instructions for restarting the update in this help file?
10-10-2019 01:48
10-10-2019 01:48
10-10-2019 01:52
10-10-2019 01:52
If you can't restart the fitbit then I think your best option would be to contact customer support via: contact.fitbit.com
If they can't fix it they can check your warranty status and advise on your options.
10-10-2019 02:01
10-10-2019 02:01
Best Answer10-11-2019 12:39
10-11-2019 12:39
Same issue, spent the last 2 days with customer support and nothing.
Since it's out of warranty they only offer a discount, really??
Fitbit broke my watch and now I have to spend $200 with the discount to get a new one??
How is that fair or even close to something called customer service?!
You broke it and now I'm out $200 if I want one.
Looks like it's time for a Garmin!
10-11-2019 12:42
10-11-2019 12:42
your options are cough up $200 dollars ( with the coupon code) if you're out of warranty for something that worked perfectly before the firmware update and now is worthless.
Why should we be responsible to fix or buy a replacement for something they broke?
