06-04-2021 14:13
06-04-2021 14:13
My ionic has stopped syncing my heart rate and sleep. The other thing not syncing is battery life. Steps sync fine. When I try to sync, the process stalls, tells me it's taking a while, and then says that it couldn't sync. Have tried every permutation of starting, stopping, resetting, pairing and unpairing with no success. All ideas welcome please !
Best Answer06-06-2021 03:42
06-06-2021 03:42
Same problem over here. Support says out of warranty. So now I'm stuck with just a step counter 😭
Already my 3th Fitbit ionic in 2years.
If you have Found a solution please share 🙃
Best Answer06-05-2021 02:47
06-05-2021 02:47
Also, not sure if this is relevant, IP address in my ionic settings is showing as "WiFi off" and the ionic is not showing on my router's list of connected devices.
Best Answer06-05-2021 17:37
06-05-2021 17:37
@richardpnewsome Welcome to the Fitbit Community. Thanks for the details mentioned.
I appreciate the troubleshooting performed prior to posting. Based in what you mentioned, it seems that your Ionic isn't syncing any data to your account.I'd like you to follow this syncing troubleshooting, even when some steps have been performed previously.
Note that the Wi-Fi will only turn on when it's downloading playlists and app from the Fitbit app gallery. It's normal that it show "Wi-Fi off", learn more about it in this article.
Hope this helps.
Best Answer06-06-2021 01:57
06-06-2021 01:57
Thanks Silvia, all done and no change I'm afraid. Any more thoughts ? (PS am also speaking with the support team via twitter DM.)
06-06-2021 03:42
Best Answer06-07-2021 01:01
06-07-2021 01:01
Hi there, followed the advice above n times, then did factory reset from the option on settings on the ionic. Took a few hours to get fully synced etc but sorted. Advice via support team on twitter was good, much more responsive. Good luck !
