09-21-2020 15:16 - last edited on 09-06-2021 16:17 by LiliyaFitbit
Not sure if anyone else has veen having similar problems with the ionic. My heart rate monitor seems to have stopped working. Noticed it first 4 or 5 days ago when it wasn't able to show full sleep stats. Have restarted a few times but still doesn't seem to be reading on the heart rate sensors. Anyone got any ideas?
09-25-2020 17:08
09-25-2020 17:08
Hi everyone! Thank you for getting in touch about this.
I appreciate the troubleshooting tried prior to posting. As mentioned by someone else above, please make sure your heart rate setting is set to "On", this can be done in the Ionic settings > turn on Heart rate.
If your heart rate is set to on but you're still not getting any reading please restart it and make sure you have installed the latest firmware version.
@Robrock83 Since you have tried performing the recommended troubleshooting, I've shared your post with our Support team and someone will contact you as soon as possible. Keep in mind that due to recent events affecting our operations we may take a bit longer to get back to you.
I'll be around if you have any additional questions!
09-21-2020 16:23 - last edited on 09-08-2021 05:07 by JuanJoFitbit
Having the same problem. Stopped working 2 weeks ago and since then sleep reports have been simplified.
I just talked to support and got a solution. On your watch, swipe left to Settings. Click and scroll down to Heart Monitor. Click on it and then toggle to Heart Monitor On. That should restart your heart monitor.
Moderator edit: merged reply
09-21-2020 23:24
09-21-2020 23:24
09-22-2020 08:59
09-22-2020 08:59
I reatarted my ionic and that fixed the heart rate monitor. To restart, hold in the side and bottom buttons until you see the fitbit logo. Hope that helps!
09-24-2020 07:04
09-24-2020 07:04
Have restarted and now got a figure but this doesnt seem to change regardless of level of activity. I've been sat working, walked around the room then ran up and down the garden and the bpm has remained the same. Feels like it needs a software update or full restart. More than just a basic reset can fix by the look of things.
09-24-2020 16:59
09-24-2020 16:59
Thank you. That worked, now how do I get it to show ion the main screen of the app in the circles area? It has always been there, but disappeared in the last system update.
09-25-2020 17:08
09-25-2020 17:08
09-25-2020 19:23
09-25-2020 19:23
Hello Silvia, thanks for your help
I also have been having issues this week with the heart rate monitor and BPM. I am bradycardic and resting HR is low 50s. I either get no reading or like now, doing nothing it sits on 94BPM. When I train, I get nothing or 170bpm. i've had this ionic over 2 yrs, once a long time ago, I restarted the watch and it all cleared. This week I have done everything suggested and still nothing. I have the latest update, i have restarted, I have turned HR toggle on and off, I even went back to reconfiguring and I am in the same situation.
I look forward to your suggestions
09-28-2020 07:55
09-28-2020 07:55
Thanks Sylvia, much appreciated. I am still having the same issues and have restarted several times since the initial post. Not sure if the Ionic is waiting for a new firmware update to resolve this as it seems to be a common problem a lot of people have been having. Larely just using the fitbit as a pedometer at the moment as without the heart rate input the calorie stats are fairly unreliable. Would be good to get back to having a full range of functionality again
09-29-2020 14:28
09-29-2020 14:28
My Ionic heartrate monitor has also stopped working. Problem looks like it started on the 24th of September which seem close to other posts. Green flashing light not functioning. No heartrate or sleep monitoring. Tried the settings and resets with no luck as yet.
09-29-2020 14:51
09-29-2020 14:51
Sounds very similar. Think mine stopped working from around 17th Sept. Very frustrating. Hopefully fitbit will have a new firmware update soon that addresses the problem.
09-30-2020 17:42
09-30-2020 17:42
@Steery @PatPasquale It's nice to see you in the Fitbit Community! Thanks for the troubleshooting tried prior to posting.
I appreciate the detailed information shared. In this case, I've shared your post with our Support team and someone will contact you as soon as possible. Keep in mind that due to recent events affecting our operations we may take a bit longer to get back to you.
@Robrock83 Thanks for the information shared. Your post has been shared with our Support team, please continue the communication through email, they'll be happy to assist.
10-01-2020 13:26 - last edited on 09-08-2021 05:08 by JuanJoFitbit
If there is answer that fixes this problem Fitbit support PLEASE POST. My ionic is new but I have tried every one of the trouble shooting tips enough times that I could write a tutorial but still no heart rate or sleep monitor. Now so frustrated I am wondering if there was a bad batch of Ionics sold. QC Fitbit where are you?
COVID killed my Fitbit?
10-02-2020 05:49
10-02-2020 05:49
I have a 1sr gen versa too and around 9/19/20, poor battery started (dead in less 12 hrs after full charge) and no heart rate/sleep monitoring. I've spent 2 days doing everything recommended and no change. My husband and I got our versa trackers at the same time. I religiously wear mine but he has barely worn his so it's basically brand new. Figuring wear and tear was the issue with mine, I decided to just start using his instead. Guess what? Same problem, no heart rate monitor. I hope this isn't a scam of forcing 1st gen users to buy new trackers by pushing a firmware update that degrades the tracker battery life and takes away functionality so all your left with is a pedometer. It's quite a coincidence that this is happening with 1st generation versa trackers and is a little too reminiscent of the iphone scandal where they slowed their older generation phones down or took away capability with a device update forcing users to think they needed to upgrade to new phones. I truly hope that's not what's going on here.
10-08-2020 13:33
10-08-2020 13:33
Sorry to share this with you. Tried all of the above, restarted, re installed. New software, chat with help desk until disconnected. Case # 37985305. Even better, every time I get back on the chat line to try to get a resolution I eventually get disconnected or dumped...... Till a few days ago very happy with Fitbit. Not now..... sometimes we try everything that is cheap and it does not work. JCE
10-25-2020 11:23
10-25-2020 11:23
Hi There,
I have the same heart rate sensor issue, looks like there is no answer yet from fitbit support.
01-23-2021 02:56
01-23-2021 02:56
Hi there
I have suddenly had the same problem. Heart rate monitor stopped working suddenly, no red or green lights. Also battery drains in just a couple of hours.
I have done a factory reset, made sure heart rate is turned on, tried to do an update but it gets stuck a third of the way along.
Not sure what else to try.
Thanks Lisa
02-17-2021 14:25
02-17-2021 14:25
Hi I have tried everything that was suggested in the forum and the heart rate monitor is still not working
03-19-2021 05:13
03-19-2021 05:13
Hey Robrock83
Did you get your problem solved? I, like you, am now having the same problem and tried everything you had. I saw that support was going to be in contact.
Any tips you could share if you got it sorted.
Cheers
Graeme W
03-19-2021 05:39
03-19-2021 05:39
