09-02-2017 17:14
09-02-2017 17:14
I'm often swimming at the beach, including surfing. Is the Ionic, fine when it comes to salt water? I of course won't be going very deep with the watch, but knowing that it can withstand waves and saltwater is rather important. Any feedback would be great, before I order!
09-05-2017 09:32
09-05-2017 09:32
@blodsbror @datalore Ionic is water resistant up to 50 meters for use in the pool, ocean, shower or rain. As @USAF-Larry @SunsetRunner said, I would recommend rinsing off the salt water after an ocean dip to prevent salt buildup, as with any other device.
09-02-2017 17:32
09-02-2017 17:32
I obviously can't answer for a product that hasn't shipped, but I can tell you I have a watch with the 50m rating and I swim often at the beach with no problems.
09-02-2017 18:09
09-02-2017 18:09
Since sweat won't bother it, it would not seem that saltwater would affect it either. But, it would probably be a good idea to rinse the saltwater off after the swim to prevent corrosion of the aluminum frame.
09-05-2017 08:59
09-05-2017 08:59
When I spoke to Fitbit, they said the Ionic was fine to swim in the ocean with. Their only caveat was to rinse it off afterwards, to prevent any salt buildup.
09-05-2017 09:32
09-05-2017 09:32
12-06-2017 17:03
12-06-2017 17:03
I surfed with my 3 day old fitbit for - like and 1 hr session - it died. I had to replace it. Now I'm scared of surfing with it again....very dissapointed that I can't track my surf 😕
12-21-2017 02:48
12-21-2017 02:48
Did you surf with the Ionic?
02-07-2018 12:04
02-07-2018 12:04
Punta Cana, here I come!!
02-07-2018 17:28
02-07-2018 17:28
I scuba to about 25 ft with mine while in Cancun in Nov 2017. I got out and used the fresh water bucket to rinse off my ionic. Never had a problem. Worked great under water too. It's been in every kind of water as well as a float spa (high salt float pod). No problems. Just rinse it really well after you get out.
02-21-2018 20:31
02-21-2018 20:31
I’ve had two sport watches that were supposed to be water proof up to 50m but after swimming in a saline pool for a few months both started digging up on the inside. I am going to swim with my Iconic and I’ll let you know what happens.
Best Answer03-12-2018 02:26
03-12-2018 02:26
@Alexandrovmwrote:Punta Cana, here I come!!
Was in the ocean at Punta Cana for half an hour (splashing, maybe 5ft) and my Ionic died. Wife's Blaze was doing just fine. Was fully charged and will not reset. Disappointed...
04-13-2018 08:46
04-13-2018 08:46
I was snorkeling in the ocean and now my Ionic will not turn on. It says it's water proof?
04-13-2018 09:31
04-13-2018 09:31
The Spec say:
Water Resistant up to 50M & Tracks Swims
Wear your watch in the pool or rain & use it to track swim workouts with stats like lap counting, duration and calories burned.
With snorkeling you go deeper than that
Put it in Rice for at least 48 hours and hopefully it will come back
Wendy | CA | Moto G6 Android
04-13-2018 14:47
04-13-2018 14:47
@WendyB wrote:The Spec say:
usually you're near the top of the water when you snorkel. ![]()
I went swimming in the ocean with it a couple times, no problems. likely a faulty unit, exchange it.
04-13-2018 14:51
04-13-2018 14:51
Your right I ead thinking Scuba Diving for some reason.
Glad you hot it exchanged
Best Answer05-16-2018 20:33
05-16-2018 20:33
I wouldn't trust the IONIC in salt water, especially to surf. Mine lasted about 3 sessions and then died. Replacement process took almost 3 weeks. I surfed again with the replacement. The first two sessions were fine, and I rinsed it each time afterwards. During the 3rd session it died again. Was able to revive the watch after a week only to figure out the touch screen no longer works. I finally convinced Amazon to give me a refund. If you want a fitness watch to go in the ocean on a regular basis, this is not the product. I wasted so much time trying to fix it, doing factory resets and all that other nonsense. Good concept by Fitbit, very poor execution.
07-08-2018 21:16
07-08-2018 21:16
My ionic died today after an hour in the saltwater .Fitbit wont replace it because i bought it from ebay
07-27-2018 10:37
07-27-2018 10:37
We are going on a cruise soon and have some snorkeling excursions planned. I know the Ionic is waterproof to 50M and that should be plenty. However has anyone had any issues with salt water causing issues with the button operation etc?
07-27-2018 11:00
07-27-2018 13:36
07-27-2018 13:36
A warm welcome to the Community @DrHuggybear! Just as @WavyDavey mentioned, you can use it because Ionic is water resistant up to 50 meters for use in the pool, ocean, shower or rain. However, just make sure you're rising off the salt water after an ocean dip to prevent salt buildup, as with any other device.
Hope this helps! Don't hesitate to share your experience. ![]()
