07-05-2018
03:22
07:23
07-05-2018
03:22
07:23
Bought an Ionic a couple months ago but recently the battery life leaves much to be desired. When I first bought it, I got 4-5 days on a single charge. Today I get to work with a battery life of 100% and 11 hours later it's at 40%. I'm hoping that it's just a fluke and won't be happening on a regular basis. Anyone else have this issue?
07-05-2018 06:08
07-05-2018 06:08
Try restarting it several times. Leg us know ifbthat gets it back on track.
Helen | Western Australia
07-05-2018 06:14
07-05-2018 06:14
Same here. Had mine for about 2 months. In the last few days I’ve had the same problem. Went to bed last night fully charged and woke up with a dead battery. Not cool
Best Answer07-05-2018 07:26
07-05-2018 07:26
Welcome to the Fitbit Community @musicmedic and @Stoop75! Sorry to hear about the inconveniences you've been having with the battery on your Ionic. Have you tried what my friend @NellyG suggested?
Keep in mind that the length of time your Fitbit device operates on a full charge depends on how frequently you use it and various settings.
Consider these tips when you want to conserve battery life:
Hope this helps, keep me in the loop!
07-05-2018 15:34
07-05-2018 15:34
Seems as though the reset worked (so far) but I noticed it has been double tracking my step count since then.
Best Answer07-05-2018 20:09
07-05-2018 20:09
I have the same issue. The battery intervals between charging seems to be degrading over time. I have not changed clock faces or functions. I might have begun after the latest upgrade.
Best Answer07-05-2018 22:54
07-05-2018 22:54
Same over here. I have my Ionic for 7 months and never had problems with it but the last 2 days I fully charged the battery and after only a few hours (3-4) the battery is dead...
Best Answer07-06-2018 01:36
07-06-2018 01:36
I am once again surprised by the quality of the answers of Fitbit representatives. In a negative way I should add.
I believe it would be much helpful to point to https://community.fitbit.com/t5/Android-App/Mobile-data-usage-increased/m-p/2813906#M78499
In there a very serious issues is reported by many users: high mobile data usage (costing money to users!), combined with high battery usage.
The lack of knowledge within Fitbit (also the helpdesk was not aware of this) and the slow response of Fitbit is beyond anything.
Best Answer07-06-2018 09:55
07-06-2018 09:55
Seems to me that we should not have to turn everything off (including shutting it off when not in use) to be able use the watch. If I have to turn my laptop off because the battery drains too fast, what is the point of having a laptop? If Fitbit would just fix the battery drain issue that would be great!
