08-06-2018
13:59
05:32
08-06-2018
13:59
05:32
Hi, I wonder if anyone has trouble with the ionic heart rate monitor? Mine seems to have stopped working all together, which isn’t monitoring my sleep correctly. I have reset the device and still not working. Also when I charge the device there is a red light on the back of the watch constantly which I have never noticed before. Any ideas? Thanks I’m advance
Best Answer08-07-2018 05:44
08-07-2018 05:44
Did you only restart once? If so try doing it multiple times and see ifbthat gets the HR monitor going.
If that doesnt work try a factory reset (the settings app on the Ionic and scroll down to About)
Helen | Western Australia
08-07-2018 09:47 - edited 08-07-2018 09:47
Welcome to the Fitbit Community @Bailey086, hope you're doing great! Thanks for already restarting your Ionic in order to solve this inconvenience, nice way to go!
Make sure that you're getting a solid heart rate reading , since sleep stages requires consistent HR. For best results, wear your device higher on your wrist (about 2-3 finger widths above your wrist bone). The band should feel secure but not too tight. Also, double check that your watch is charged up.
Additionally, I'd recommend checking the following that could be preventing you from receiving sleep stages:
For more information about why you see your sleep pattern, tap or click the sleep record that shows your sleep pattern.
In regards to the red light, the optical heart rate tracker turns red during the tracking of sleep and changes to green shortly after the customer is awake. This is an expected behavior not an issue.
Thanks for your help @NellyG! ![]()
Give this a shot and let us know how it goes!
