06-16-2018
13:09
09:30
06-16-2018
13:09
09:30
I am having a similar problem with my Ionic. It recently stopped tracking steps and heartbeat.
I have updated the application (version 2.7.3) and have updated the firmware (version 27.32.10.15)
I also have deleted and removed the Ionic twice.
I did a factory reset of the device twice.
When the firmware is being updated I noticed the phone app kept spinning, so didnt seem to finish.
Not sure what to try next.
02-25-2020 05:12
02-25-2020 05:12
Whats steps should a person try before deleting the app to restart.
Best Answer02-25-2020 05:23 - last edited on 02-27-2020 16:50 by LiliyaFitbit
Not sure there ever was a fix to this. I believe the underlying software in the device was corrupted by an update - Fitbit sent me a new one for half price. If the tracker is working but it’s not syncing to the app, then deleting and re installing could potentially work.
Best Answer02-25-2020 05:32
02-25-2020 05:32
Best Answer02-27-2020 14:36
02-27-2020 14:36
Best Answer03-14-2020 10:29
03-14-2020 10:29
I am also having same problem; bit less than two year old Fitbit ionic is not tracking steps or BPM. Also GPS tracking does not go on when running. Problem started after recent update few weeks back. It seems to be a fundamental flaw in the software as the problem persists even people reported same problem already two years ago. Maybe not really a trustworthy company if they do not take responsibility. I did restart, changed clock face several times, returned factory settings, switched on/off etc
Best Answer03-14-2020 10:35
03-14-2020 10:35
seriously problematic firmware.
& seriously problematic customer service.
My ionic is also on this cursed firmware.
It cannot shut down properly. (Known problem which fitbit doesnt acknowledge)
Many users complained that if factory reset it will go into loop. Scary.
My ionic is giving false heartbeat readings even when im not wearing it.
Sometimes as high as 150 BPM and beyond. lol. And it detects sleep when there is none.
I emailed Fitibit and they asked me to reset. I told them many users complaining reset will cause their watch to die so if die will fitbit replace for me? they basically wash hand as said that they will check later. Hahahahaha! Die first then will talk. I am amazed at such low quality of customer service.
Good luck solving your problem. Dont think it is the only problem that will go unsolved. 😞
Best Answer03-14-2020 10:50
03-14-2020 10:50
Best Answer03-14-2020 10:53
03-14-2020 10:53
Best Answer03-15-2020 17:52
03-15-2020 17:52
My ionic does not count my steps anymore + the tapping on the screen does not work either
03-29-2020 17:01
03-29-2020 17:01
My turn to just start having this issue as well. I seem to have been luckier than most on here though. I got my Ionic December 2017 and this issue just started happening yesterday. I’ve tried several reboots, factory resets and reconnects to the app. Changed and reset watch faces. Nothing seems to be working. I guess it’s time to start shopping around.
03-29-2020 17:10
03-29-2020 17:10
I did start shopping and went with Apple Watch
04-20-2020 17:19
04-20-2020 17:19
I'm having this problem now. Is there a solution?
Best Answer04-20-2020 17:51
04-20-2020 17:51
For me, unfortunately, nothing I could fix at home. I had to send my watch back in and Fitbit sent me a new one.
Best Answer04-20-2020 19:45
04-20-2020 19:45
Best Answer04-20-2020 20:29
04-20-2020 20:29
Having the exact same issue... no BPM, no steps, tried all the fixes - Still not working. Can't believe Fitbit isn't honoring a fix to this issue...
04-21-2020 16:49
04-21-2020 16:49
Best Answer05-28-2020 19:43
05-28-2020 19:43
I’ve done all of that and mine is still not working.
Best Answer06-03-2020 16:02
06-03-2020 16:02
Mine too, weeks of frustration with this ionic. This after paying 250. For a fix last Fall🤔 so no offers from Fitbit for me.... OVER 500.00 into this in two years.... ALL suggested remedies attempted. I realize my retirement time is fleeting. I am finished with this. Maybe the fish in the Sound would like to know the time! For 24 hours or so anyway. no no not that. I will recycle it🤨
Best Answer06-29-2020 20:44
06-29-2020 20:44
Hi,
The same thing just happened to my watch too, can you pass on that info or start a ticket for me too please?
Thanks,
Shirah
Best Answer07-22-2020 15:00
07-22-2020 15:00
My ionic is doing the same thing. Won't count steps, floors or track heat rate. I've Uninstalled a few times, did a hard restart, factory reset ... still no luck!
