01-03-2021
13:34
19:54
RicardoFitbit
01-03-2021
13:34
19:54
RicardoFitbit
My Ionic has been working fine over a year and then I noticed it has stopped tracking steps and heart rate. Additionally, it seems to have gone from full charge to only 35% in about a day and a half.
It also started lighting up at night (in bed, even though it shouldn't) and doesn't react properly when I turn my wrist to see the time (need to over exaggerate like mime). I've reatarted the device and tried updating and resetting it. No joy. Please help.
Best Answer01-03-2021 19:54
01-03-2021 19:54
Hi @Thanassi360, welcome to the Community Forums.
Thanks for bringing this to our attention and for trying some troubleshooting steps before posting over here, seems odd that your Ionic is behaving in such way. To fix the issues you're currently experiencing, I'd like to recommend you our factory reset procedure. To do so, please follow the next steps and let me know if the issue persists:
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Let me know if further assistance is needed and if you have any additional questions.
Best Answer01-04-2021 15:52
01-04-2021 15:52
Hi @RicardoFitbit ,
Thank you for your reply.
I have tried these steps as requested and the device is still not reading heart rate and after a quick jog around the house, there are no steps added.
Any other ideas?
I believe it is still within the 2 year warranty here in the UK.
01-04-2021 20:19
01-04-2021 20:19
I have experienced identical issues over the past few weeks. Fixed the first time by allowing the battery to fully drain, charging and restarting. This time no of the 'fixes' are working😔
01-05-2021
07:49
16:54
RicardoFitbit
01-05-2021
07:49
16:54
RicardoFitbit
I see they still must not have fixed the last update that messed with mine in Oct. AND now I see you are going to discontinue the Ionic??? that is just crazy, for awhile it was the best Fitbit you had. NOW just figure out why the update screwed it up and you will have alot of happy customers.
Moderator Edit: Content
Best Answer01-05-2021 07:54
01-05-2021 07:54
and they won't do anything to fix it. Back in Oct/Nov they FITBIT messed with all the Ionics and refuse to fix it, but they will off you a $35 towards another fitbit. This is my third fitbit to go to hell on me. I had the Blaze before the Ionic and that did the same thing
Best Answer01-05-2021 10:27
01-05-2021 10:27
Has anyone looked at twhen this started - Im seeing the same things with my Ionic - HR went grey - no steps etc - seems to have started on Jan 1, 2021. Was working fine until then.
Best Answer01-05-2021 14:38
01-05-2021 14:38
With my ionic IT also started on 01-01-2021.
IT seems it has to do with the last update, but receive no help from Fitbit.
