06-16-2021 13:07
06-16-2021 13:07
Hi all
On my last few runs I have got home to find that my route wasn't mapped as my Ionic hadn't connected to GPS, so no splits or accurate distance recorded.
I have searched online and seen advice to switch off and on again, didn't work. Advice to sit it outside for a few minutes to search for a signal, didn't work.
So today I did a factory reset and I got it to connect. Found it hard to contain my excitement so went for a walk to test, 0.21 miles in it disconnected and didn't even try to reconnect.
So I'm after ideas of what else i can try before leaving Fitbit after many years and many devices.
Best Answer06-17-2021 12:11
06-17-2021 12:11
Welcome to the Fitbit Community, @fairfaxfarquar.
Thanks for the details shared in your post and for already trying to resolve the issue. I understand how you are feeling about this situation and recommend trying the following:
Check if your Fitbit app is updated to the latest version as updates come with new features and bug fixes: How do I update the Fitbit app?
For more information about tracking your activity with GPS, see How do I use GPS on my Fitbit device?
Hope this helps.
