08-13-2020 03:30
08-13-2020 03:30
My Ionic (only about 18 months old) has been running slow with the time last several days. I reset time zone which updates to current time, but continues to run slow. Now I can’t connect to Bluetooth. Very frustrating.
08-13-2020 12:18 - edited 08-13-2020 12:19
I have this problem it wont pair to my phone. Very frustraed all the data appears to be tracked on watch only. I get the code from the tracker and then the app can't load it. I have restarted and rebooted several times. I lose 2 mins on the hour which doesn't make any sense at all. Now I can 't even see past data on my account it is all gone due to no device being synced. What has happened?
08-13-2020 05:34 - edited 08-13-2020 05:35
It must be going around. I woke up to my Fitbit alarm this morning, set for 7:30 am. I turned off the alarm, got up and looked at the clock on my nightstand and it said 8:20 am. The watch is charged and it last synced around midnight. I'm not sure what to do. If I can't rely on the alarm, which I use religiously, then the watch is of no use to me.
Best Answer08-13-2020 11:10 - edited 08-13-2020 11:11
If I have to buy a new watch, I will probably switch to the Apple Watch. This ionic cost more than the series 3 apple, and if it isn’t going to last, then I don’t want another. 😡
08-13-2020 13:54
08-13-2020 13:54
08-18-2020 00:20
08-18-2020 00:20
Same problem here. overnight the watch is 14 minutes behind. Can't imagine the watch is not showing correct time if not connected to the phone. This happens since last week/2 weeks ago. I have a versa 2.
Even have a lot of sync issues. Not sure if these issues are connected
Best Answer08-18-2020 05:27
08-18-2020 05:27
