05-18-2020 14:03
05-18-2020 14:03
My watch keeps losing wifi connection. I recently tried to upload a new playlist of audio book chapters and lost count of the number of times that I had to restart the watch to refind the networkand it often struggled to find the network even while sat on top of the router. Since completing I've not had anything but 'Wi-Fi off' under IP address.
While listening to the book my headphones often dont show under the bluetooth menu and will not pair, restart the watch a couple of times and it will show again. Sometimes it will then play the chapters for a while but usually it will cut off after a minute or so and again the headphones wont show, usually the watch will forget where the media track got to as well so have to restart.
A connected query, is there a way to fastforward or rewind through media files or can you just skip to start/previous/next?
05-18-2020 14:22
05-18-2020 14:22
Trying to connect to wifi now with the 'About' menu open so that I can see the IP address. I reset the watch so that it would at least see the network when I use wifi setup. When I click on the appropriate network my watch says it is connecting for a while and then an IP address flashes up briefly before resetting to 'Wifi off' even before the laptop app says that it is successfully connected so I am able to close that window and immediately begin the process again.
