03-16-2018 11:22
03-16-2018 11:22
How do I use my phone to unlock ionic
03-19-2018 10:28 - edited 03-19-2018 10:30
I've never done this but I note a Device Lock setting so you can go to the Fitbit App, click on the Account icon at the upper right (looks like a page) and then on Ionic. Scroll down to "Device Lock". I assume you set this at some point and apparently had to use a PIN so now you will probably need that to Unlock.
I've never had this question or seen it asked before so please let us know what the outcome is.
03-19-2018 11:40
03-19-2018 11:40
@19prb61wrote:How do I use my phone to unlock ionic
So this may also help you:
So, If you enter an incorrect PIN code 10 times, you're prompted to unlock your Fitbit watch with your paired phone.
To unlock your watch with your phone:
Note that after you reset your PIN code, you must add your cards to Fitbit Pay as if you were setting it up for the first time.
If the steps above don't work, please turn off everything that is Bluetooth enabled. Tablets, PC, other phones. Wireless headphones hanging around - power off. You don't want any stray 'signals' effecting this process. Then, remove your Ionic from your phone.
This was provided by Moderator @MarreFitbit
Hope this additional info helps!
Gunny | Richmond, VA (USA)
Ionic Adidas Edition, Versa Special Edition, Aria 2 & Flyer | iPhone & Windows 10
Take a look at the Fitbit Help site for further Assistance & Information.
