11-02-2020 10:31
11-02-2020 10:31
My Ionic lost its correct time for he umpteenth time. I have managed to reset it in the past. This time however it will not reset. I tried a hard reset but now all I get is a red cross and Data not cleared. Sync & try again. It will not sync now just comes back to same error,
Best Answer11-02-2020 20:34
11-02-2020 20:34
Hi @KevCor when you say Hard(ware) Reset, are you recovering to a shutdown of the tracker?
Or are you referring to a factory reset, which seems to be a sure way to clear this data error.
Doing a sync usually does work.
