07-18-2019 09:01
07-18-2019 09:01
A place you hit the button or something while wearing watch and now it's locked out. I touch screen Nx it says "unlock with your phone". How do I do that as can't find a way.
Best Answer07-18-2019 13:36
07-18-2019 13:36
By going into the Fitbit app, account, ionic, device lock, change pin.
You will be asked to enter the phones unlock code.
This is all explained in the help docs
Best Answer07-18-2019 19:19
07-18-2019 19:19
You can’t, this is a glitch in the software the will have to replace your ionic.
If you are out of warranty you are screw. Be aware these watches life span is just one year, 18 months top.
Best Answer07-19-2019 11:44
07-19-2019 11:44
You can't what, @frankmch I have purposely messed up and locked the tracker. Using the Fitbit app it took less than 30 seconds to unlock.
The other way that has been proven is to do a factory restore.
