02-27-2019 18:33
02-27-2019 18:33
Hi all,
I have the Ionic which was my partners. He gave it to me and disconnected his phone so I could connect mine but I never did. Just used it without connecting to my phone at all. My niece was playing around with it and it is now saying "unlock with phone" but neither mine or my partner's phone is connected to it.
My partner tried to reconnect but it wouldn't let him. I have also tried to connect and it won't allow me to either.
So how can I unlock it if it's not connected to any phone?
Best Answer02-27-2019 19:19
02-27-2019 19:19
1st step, if the ionic is telling you to use the Fitbit app on the phone to unlock the tracker. Removing the tracker from your Fitbit account will prevent you from doing this.
Normally a quick search of the help docs will provide the answer..
See the last question.
How do I use the device lock on my Fitbit device?
If the ionic was setup to only lock Fitbit pay you would be able to re-add..
We now have to do a factory reset using the button method.
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
02-26-2020 01:31 - edited 02-26-2020 01:35
Hi, I followed this exact procedure, it did the strong vibration but just went blank straight after it and wouldn't turn back on?
Please help, I've put it on the charger even though it's already charged but it won't even show the charging sign
Best Answer02-26-2020 09:53
02-26-2020 09:53
@Jmohtadi what process did you do.
When it asks to unlock with phone, they user needs to simply use the app to change the pin code
Best Answer02-26-2020 10:24 - edited 02-26-2020 10:28
@Rich_Laue I tried everything to unlock it with my phone for hours but it just wouldn't unlock. I ended up following the factory reset process you put up, my ionic did viberate but just went blank and wouldn't turn back on
