10-15-2017 16:15
10-15-2017 16:15
So I have a very short time frame of experience with the Ionic - 24 hours. It has been a painful time with the Ionic not staying connected to my phone (Pixel XL running 8.0). But during the past 24 hours I have had to restart or repair the ionic numerous times in order to get the watch to sync only to have it stop syncing within an hour or so. I have reached out to support a couple of times and each time they have given me steps to get it connected - BUT that is not sustainable to do daily.
I cannot be the only one with this problem. A quick search showed some steps to fix it which only work less than half of the time.
I am trying to figure out at this time if it is software or hardware problems..... I really like the watch and want to get mine working with no problems. I had been using a One and there was never any issues with sync or connections to my phone.
Honestly not sure what I am expecting to get from this post - maybe someone else had the same issues that they fixed?
01-11-2020 17:07
01-11-2020 17:07
Yes, the same thing is happening. My Ionic is 6 months, they’ll send a replacement. I’ve heard Garmin is really good, though.
Best Answer01-11-2020 17:14
01-11-2020 17:14
Best Answer01-11-2020 18:18
01-11-2020 18:18
Best Answer04-10-2020 11:40
04-10-2020 11:40
For anyone reading this, this app solved all my sync issues. I've been using it for 3 days now and I've had no more issues whatsoever. Before installing the app, I had to unpair my fitbit ionic multiple times a day to regain connection to the fitbit app.
I'm using a Huawei Mate 20 Lite, with Android 10.
