02-05-2019 02:51
02-05-2019 02:51
The most frustrating pc of tech I have ever owned. I have tries restarting phone/bluetooth/watch...deleting ionic and adding again! I just haven't got the time in the day to do anything else!!
02-07-2019 10:50 - edited 02-07-2019 10:51
A warm welcome to the Community @Steve1974! Thank you for the troubleshooting that you've tried. If your Ionic isn't syncing, this might be the reason why it doesn't have the correct timezone.
I would like you to confirm that you've followed this syncing procedure step by step.
Hope this helps. I'll be around if you need further assistance.
Best Answer02-07-2019 11:12
02-07-2019 11:12
I'm having the same issue, it is not syncing with my iPhone. It started to have problems after the latest upgrade to the Fitbit IOS 27.33.1.30. I have tried all the recommended sync solutions and still not working. The Fitbit Ionic does not appear as a device to sync in the Bluetooth list on the iPhone.
02-07-2019 11:36
02-07-2019 11:36
02-07-2019 12:59
02-07-2019 12:59
I was having the same issue, however, I uninstalled the app, and factory re-set. Now
the tracker will not power up. pls. help.
there was plenty of charge. Still s/b
02-07-2019 13:54
02-07-2019 13:54
Not sure on that one I'm afraid. Maybe just keep trying to reset. Sorry!
Best Answer02-07-2019 18:23
02-07-2019 18:23
My ionic started having the same issues about 2-3 weeks ago. I called customer support and went through all the trouble shooting they suggested. As a last resort I was told to do a factory reset. After that it worked for 10 days before it stopped syncing. I also uninstalled the app and did another factory reset. Now my Fitbit won’t even power up and it was at almost full battery. Their only solution was to offer me a 25% off coupon for another watch that may possibly have the same issue. There are a lot of us in the same boat. Fitbit does not stand behind their products. They need to do a recall for an obvious defective product.
02-07-2019 19:24
02-07-2019 19:24
Best Answer02-07-2019 19:27
02-07-2019 19:27
You are lucky.
Best Answer02-07-2019 19:28
02-07-2019 19:28
Best Answer02-09-2019 16:10 - edited 02-09-2019 16:12
Welcome to the Community @Steven25! Thank you so much for mentioning that you have an iPhone and using the latest version of the Fitbit app. I also appreciate the troubleshooting that you've mentioned.
Since, your Ionic isn't paired to your account anymore. I would like you to follow the set up process again. (Remember to set it up as a replacement device)
Thank you for sharing your experience with our Support team @michaelj175 and @JasmineTG. Each case is reviewed individually and the solution that's provided is always based on the Fitbit Warranty.
Best Answer09-09-2019 10:26
09-09-2019 10:26
My Ionic started counting less steps than normal a little over a month ago. Just last week, I noticed that the time was not correct. The time loses over a period of time and is not a "timezone" issue. This morning(6:02 a.m.) after syncing at 9:49 p.m., it was 1 hr 38 min off. I've tried up to and including,resetting to factory defaults, deleting and resetting through the app. I purchased the product 1 yr and 8 mos ago and now I can't trust it to do the 2 things I need the watch to do. Is there anything Fitbit can do to help me?
Best Answer09-11-2019 12:53 - edited 09-11-2019 12:54
Welcome to the Community @Regg50. Thanks for the details mentioned. Sorry for the delayed reply.
I appreciate the troubleshooting tried. Since, you've tried restarting it and performing a factory reset but it's still not working, I've shared your post with our Support team, they will continue assisting you and providing you with options.
Best Answer03-02-2020 18:06
03-02-2020 18:06
I'm having the same issue. Lost time and not syncing with my phone. Started a few days ago. Very frustrating
03-04-2020 14:00
03-04-2020 14:00
@Happiness526 Welcome to the Community. Sorry for the delayed reply.
Thanks for the details mentioned. I appreciate you mentioned how this situation made you feel.
The reason why your Ionic lost the timezone might be due to not syncing to your phone. I would like you to try this syncing troubleshooting.
Keep me posted. I'll be around if you have any additional questions.
