12-21-2018
23:40
07:14
SantiR
12-21-2018
23:40
07:14
SantiR
Worked well for months. Now it sees the Q12 and just hangs when connecting. Q12 works fine pairing with other devices.
Moderator Edit: Format
12-23-2018 07:13
12-23-2018 07:13
@SunsetRunner Welcome to the Fitbit forums! Thanks for taking the time to share the situation you are experiencing pairing your Bluetooth headphones to Ionic.
In this case, you could try performing a restart on Ionic. Then, you could try re pairing the headphones.
Also, if the headphones are paired to other devices nearby, please disconnect. You could also try turning off Bluetooth from other devices so the signal doesn't get interfered.
Hope this helps. Keep me posted!
12-31-2018 07:24
12-31-2018 07:24
01-07-2019 14:35
01-07-2019 14:35
@SunsetRunner Thanks for your reply and for sharing all of those details.
I went ahead and contacted you via PM. Please keep an eye on your Community inbox.
Also, regarding the features you would like to have on your watch; feel free to post them on the Feature Suggestions Board. I found one similar to what you are asking, feel free to vote for it:
Keep me posted!
