02-12-2019
17:05
11:05
SilviaFitbit
02-12-2019
17:05
11:05
SilviaFitbit
My never ending issues with my Ionic continue. I went to charge it today when it was down to about 10%. I looked at it and it was still charging at 82% so I know it was charging. A bit later I took it off and it was dead. No screen, no green light on the back. I tried the three button reset and the two button reset (back and bottom buttons). Nothing worked. It's totally dead. Anybody have any ideas?
Best Answer02-18-2019 07:31
02-18-2019 07:31
It's great to see you around @Hsbi. I would like you to restart your Ionic and make sure you're fully charging it. This time, you can try to changing USB ports.
Hope this helps. Let me know the outcome.
Best Answer02-14-2019 11:04
02-14-2019 11:04
It's great to see you around @ssaslow! I appreciate the details that you've mentioned as well for the troubleshooting that you've tried. In this case, I've created a case on your behalf with our Support team, they will continue assisting you on this matter.
Hope this helps. I'll be around if you need further assistance. ![]()
Best Answer02-14-2019 14:21
02-14-2019 14:21
I have the same problem with mine. Started today.
02-18-2019 07:31
Best Answer02-18-2019 09:58
02-18-2019 09:58
Unable to recharge as the unit is completely dead, cannot reset and had already cleaned the charging points and tried a number of alternative usb ports. All to no avail. But thanks for trying to help.
02-18-2019 11:36
02-18-2019 11:36
welcome to the club! They continue to tell you to restart it even after you tell them it's totally dead.
02-18-2019 14:46
02-18-2019 14:46
Mine did the same yesterday; it's been on charge for about 4 hours and still won't turn on
Best Answer02-18-2019 14:54
02-18-2019 14:54
I am having the same issue, however my battery was showing medium when the screen went black. I have it charging now (yes I verified the plug is functioning) and no matter the button pressing configuration I use cannot get the watch to turn on. Very disappointed!!!
02-18-2019 14:56
02-18-2019 14:56
Mine started that today to. Ive also tried the 3 and 2 button reset. Tried different usb ports and still a black screen. This has happened a few times before to me but always ended fixing itself. Not so much this time. Seems to be DEAD. Always seems to do this while it was charging. It did say 0% for a lil bit, never went up though. Anyone else have anymore ideas?
02-18-2019 16:03
02-18-2019 16:03
Sadly Fitbits response was too bad, we are ok with our products not lasting more than 14 months
02-18-2019 16:10
02-18-2019 16:10
Yep! They don't even try to make the product work better. I am leaving fitbit for a Samsung galaxy watch. I'm sure that will be better or at the least they will care of their most expensive product will give the notifications it's suppose to and work for more than 14 months.
02-18-2019 16:33
02-18-2019 16:33
Same here.
I hadn't used it in a couple weeks. Was working fine before. Put it on the charger, didn't see the green light on the back flash or anything, so I assumed it was just "really dead".
Charged overnight, but nothing the next day.
When I did the 2 button reset, after about maybe 45 seconds, I saw a big red exclamation point on the display for maybe 2 seconds, then blank again.
I tried the reset agin, but I couldn't even get the exclamation point to show.
Unless the charging cable is suddenly bad, my Ionic seems to be toast.
02-18-2019 19:23
02-18-2019 19:23
I purchased this Ionic in November 2017; took it back to the store this morning and they replaced it free of charge.
02-19-2019 13:18
02-19-2019 13:18
Thank you for getting back @Hsbi. I've shared your post with our Support team and they've mentioned that you already have a case with them. Please continue the communication via email.
Hey @ssaslow. Our Support team provides you with some troubleshooting in order to fix any issue that you might be experiencing. After all the procedures have been exhausted, they will provide you with options to resolve your case, they will always follow the Fitbit Warranty.
Great to see you around @McKerl. I was reviewing the other post that you have and I'm glad to hear that you got a replacement. Hope you can continue enjoying it.
Hey there @JBataguas. I appreciate the troubleshooting that you've performed. I've shared your post with our Support team and they've mentioned that you already have a case with them. They will continue assisting you and provide you with a solution based on the Fitbit Warranty.
Welcome to the Community @AgangerLS1 and @SunsetRunner. I appreciate the details that you've mentioned as well for the troubleshooting that you've tried. When you're experiencing this type of issue, then you should try to restart your Ionic and make sure you're fully charging it. However, I've noticed that you have a case with our Support team, please continue the communication via email.
I'll be around if you need any assistance.
Best Answer02-19-2019 15:43 - edited 02-19-2019 15:45
I do have a case with the support team - but after the first response late Sunday and my reply early on Monday morning - it has all gone quiet. It seems that my 'ticket' has gone down a rabbit hole! Not happy at all.
02-19-2019 21:23
02-19-2019 21:23
Me too. It was showing 0% when I put it on to charge. I figured it would charge just fine. I went to check it after 5 hours and it said 0% then went black. I tried all of the suggestions pushing all 3 buttons, pushing the left and bottom button. Nothing. I saw one thing that said to go into settings on the watch, but you can't do that with a black screen. I cleaned everything and checked the charging station. It is working bc the rest of the things plugged in are charging just fine. I haven't even had it for a year yet. I really hope I can get it fixed bc I have bragged about how great it is to everyone I know.
02-19-2019 21:40
02-19-2019 21:40
02-20-2019 05:30
02-20-2019 05:30
I have the same problem. Started yesterday. I did everything , but it is still dead. Called customer service with NO help. BTW my Fitbit Ionic is 1 year and 38 days old and they only warranty for 1 year and 30 days. NOT a happy customer.
02-20-2019 05:43
02-20-2019 05:43
Yep. My Ionic is trash of course around the 13th to 14th month of ownership. Fitbit will do nothing for it, even though it is a $250 piece of trash. Can't believe this company is so poorly operated. I am now off to join the Apple Watch train as well. I am quite sure my experience will be better there anyhow.
02-20-2019 05:57
02-20-2019 05:57
I am 14 months in but here in Europe the warranty is 24 months - but support does not seem to be prepared to engage in any email discussion, after first message to charge and to reset (impossible as the fitbit is dead) they have not responded to a number of emails.
