07-01-2018
10:42
10:50
MattFitbit
07-01-2018
10:42
10:50
MattFitbit
Ionic only a month old and battery went flat now it won’t charge or switch on at all tried to do factory reset what next?
Moderator edit: edited title for clarity.
07-12-2018 20:19
07-12-2018 20:19
Same thing happened to me. They put me through an exhausting support gauntlet and then weaseled out of the "1yr manufacturer warranty" anyway. I hope you have better luck than I did. 6 months is too little life for a $300 watch.
Best Answer07-13-2018 11:36
07-13-2018 11:36
Thanks CB.
I was hoping for some user experience feedback or possibly a response from FitBit support on this board since they've responded to others with similar issues.
It not, I'll reach out to them directly.
Best Answer07-13-2018 13:05
07-13-2018 13:05
Fitbit Customer Support does not monitor this User Forum. That's why I gave you their site.
07-13-2018 13:08
07-13-2018 13:08
Got it. I'll contact them directly.
I thought that I saw some official FitBit communications in other threads under Product Help Forums.
Sorry for the confusion.
Best Answer07-13-2018 13:17
07-13-2018 13:17
I understand. There are some Fitbit Employee Moderators here on the Forums with us volunteers but they are not direct representatives of Customer Support.
07-14-2018 00:58
07-14-2018 00:58
My ionic has went dead. I put it on charge last night and it hasn't changed at all. The screen is still blank and no sign of charge I have tired the usb in a different plug and still nothing???
Best Answer07-14-2018 03:26
07-14-2018 03:26
How you tried the troubleshooting steps in the following help article - Why isn't my battery charging?
07-14-2018 06:21
07-14-2018 06:21
Best Answer07-14-2018 06:23
07-14-2018 06:23
Bought my granddaughter an Ionic for Christmas. Won't hold a charge and side buttons do not work. Tried the 2 methods suggested for reset without correction. Frustrated, cant find a number to talk to anyone to have this corrected or replace. HELP PLEASE - IDONT HAVE TIME TO READ THRU ALL THESE POSTINGS
Best Answer07-14-2018 06:54
07-14-2018 06:54
@JewelDancer I've merged these threads as they were a duplicate.
To answer your question, you can contact support using this link. You will be presented with a number of options to get in contact.
07-17-2018 09:45
07-17-2018 09:45
@SunsetRunner I thought about you today.
So they received mine on 7/3. I wrote them last week after it had been 5 business days not including the holiday. Here is what they sent me on 7/11:
Best Answer07-19-2018 16:18
07-19-2018 16:18
My fitbit won't charge and the bottom right button fell off.
Best Answer07-19-2018 22:29
07-19-2018 22:29
Hello @SophiesNonie12
Give Fitbit a call, email or chat.
They should have a solution for you
Here is the help link
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
07-20-2018 07:03 - edited 07-20-2018 07:04
Got the Ionic for Christmas. Hardly any problems whatsoever. However I recently my ionic died and went to the 0% battery screen. Oh well, I'll charge it overnight. WRONG. The watch will not turn on. When I plug it in, I feel the vibration signifying the charging of the device. Considering getting the cheaper, and more reliable Misfit Vapor if this problem persists...
Edit: tried to reset the ionic with factory reset, soft reset, hard reset, etc. No dice.
Best Answer07-20-2018 07:06
07-20-2018 07:06
Contact Customer Support. Your watch is still under warranty.
07-20-2018 07:13
07-20-2018 07:13
Hey there @GottaRunFast, it's nice to see you around the forums! Sorry to hear that your Ionic is not turning on after the steps you've followed. Nice way to go, btw! ![]()
I have reached out to our support team and created a case regarding your inquiry. Someone will be reaching out to you within the next 24-72 hours with next steps. ![]()
In the meantime, please try the steps I've posted here.
Thanks for your advise @SunsetRunner!
I'll be around if you need further assistance!
07-21-2018 12:14
07-21-2018 12:14
My ionic's battery died after six months, and the initial symptoms were exactly as you describe: reduced capacity to 2 days, then 1 day, then a few hours, and finally it went so flat that it didn't even make it off the charger. Fitbit put me through an exhausting support gauntlet before finally refusing to replace my watch, leaving me high and dry. Six months is too little life for a $300 watch, but not according to fitbit!
I hope you have better luck.
07-21-2018 12:27
07-21-2018 12:27
So I've read up to see if anyone else has been experiencing crazy battery drain on their Ionic, or any other Fitbits. I only saw that something occurred about 10 days ago, and Fitbit released an update to address this (2.74.2). In addition I've uninstalled the Fit bit app and re-installed it, factory reset the Ionic, and turned off (1) Always connected, (2) Keep-alive Widget, (3) Reminders to move, and on top of that I never keep my bluetooth on as I don't care for text message notifications. Nonetheless, here's how my battery is holding up: Today at 2:56: 100%, and right now at 9:53: 67%. A loss of 33% in about 7 hours is absolutely ridiculous given that I've only turned on bluetooth to sync it about two times. This sudden inability of the Ionic to hold a charge started about a week ago, I'd say, which seems to coincide pretty nicely with this crazy bug they let out. Is anyone else experiencing this? I'm over in Germany, so not sure if that would be useful in any way.
Looking forward to having 5-6 day battery life again.
Thanks in advance!
Best Answer07-21-2018 12:33
07-21-2018 12:33
Good afternoon those of you who know and do not solve but instead obfuscate.
I am about tired of the charging issue that periodically arises.
Did you reset? Haha... How many times? 100?
Did you clean connectors? No S Sherlock.
Did you this? Did you that? Yep did it all.
This power charger? Do it on computer? Oh its sensitive...
The correct answer is that it doesn't work right.
Every so often it is a pain in the rear to charge.
This wastes so much time dinking around with it.
Happened just before a 1/2 marathon, the dang thing wouldn't charge.
Instead of focusing on the race and having family time, I'm messing with the stupid watch.
Dear folks. It doesn't charge right. End of story.
Best Answer07-21-2018 12:37
07-21-2018 12:37
Watch went off after I came back from a run. Has been on charge, won't reboot
Please advise on what to do next.
