07-08-2019
12:07
11:58
SilviaFitbit
07-08-2019
12:07
11:58
SilviaFitbit
I ran 16K and my Fitbit shows zero activity minutes. I ran 1:52 and HR showed incorrectly also (no way it was 93!)
Help!
I have done a reset and no change
Best Answer07-09-2019 12:03
07-09-2019 12:03
Welcome back to the Community @pamruhl. I appreciate the details mentioned.
It's pretty weird that your active minutes aren't showing and your heart rate is incorrect. I would like you to double check this article to learn how your active minutes will be calculated. Also, check this article about how do I track my heart rate with my Fitbit Ionic?, there you will learn some tips on how to improve your heart rate.
I would like you to double check that there are no activities logged that might be interfering with the information you're getting.
