11-10-2020 23:24
11-10-2020 23:24
I used the watch while swimming, it was on then, later I had put it for charge, since then its not switching it on.
tried restarting, hard resetting!
is there anyway to get it repaired?
From India
Thanks!
16:33
11:57
11-13-2020
16:33
11:57
@Rungta It's nice to see you in the Fitbit Community. Thank you for the troubleshooting tried.
I've shared your post with our Support team and they mentioned you already have a case with them, please continue the communication through email, they'll be happy to assist.
Have a great weekend.
Best Answer11-13-2020 21:02
11-13-2020 21:02
Hi I too have got similar problem. Ionic is not switching on since morning today. Was working till 5 Am this morning. Tried every possible combination of resetting. It’s not switching on. Will be really grateful for the help and support to get it started. My Ionic is 2 years old. Has the battery outlived it’s life. I am from New Delhi, India. Thanks in advance.
13:06
11:57
11-14-2020
13:06
11:57
@DiganntaaSircar A warm welcome to the Fitbit Community. Thank you for the troubleshooting tried prior to posting.
In this case, I've shared your post with our Support team and someone will contact you as soon as possible. Keep in mind that due to recent events affecting our operations we may take a bit longer to get back to you.
Best Answer11-14-2020 16:12
11-14-2020 16:12
I had my FitBit Ionic sitting on my dresser for several months (not on a charger). Today I decided to used it and it won’t turn on when I put it on the charger (won’t even give me the red “dead battery” icon. I chatted with tech support and they had me clean the connectors with alcohol and a toothbrush then plug it in for 30 minutes. Nothing happened so I ran out and bought a new OEM charging cable. Still nothing after 15 minutes. We shall see but I think it has died for good.
Best Answer11-15-2020 05:31
11-15-2020 05:31
Best Answer11-15-2020 08:18
11-15-2020 08:18
I had the same problem and read to charge it from your computer instead of a outlet...my understanding the charge from the outlet is stronger and confused the Fitbit.It worked
Best Answer11-15-2020 18:33
11-15-2020 18:33
Best Answer11-16-2020 12:29
11-16-2020 12:29
Why didn't you set this up for me?
Best Answer11-17-2020 07:57
11-17-2020 07:57
I have the similar problem. My fitbit ionic arrived to zero % baterry and when I ried to charfge, it was not charging and it was not possible to re-start.
I suffer this first some time ago during the time of guaranty. I when to the shop, they submitted to fitbit service and was returned back with the note that fitbit does not guranty that. Fortunately the shop (Decathlon) gave me guaranty and they supplied me with a new one. Several months later, I had again the same problem, and after many tries I was able to restart. However, now I have again the same problem, I have tried everythig possible (charging from several computers, from an external battery, from several chargers, and no response at all). An additional problem is that there is no way to find instruction about which botton must be pushed for restart.
WE NEED HELP, AND BETTER RESPONSE FROM FITBIT, PLEASE
11-17-2020 11:34
11-17-2020 11:34
I’ve had the same thing 3 times now, Fitbit replaced the watch for me 3 times but now this one has gone too.. have just raised another support request. Must be an issue with them all?!
Best Answer11-17-2020 15:12
11-17-2020 15:12
Best Answer11-17-2020 18:52
11-17-2020 18:52
Eigenio- they don't seem to care about us anymore.
