05-17-2019
06:40
16:14
SilviaFitbit
05-17-2019
06:40
16:14
SilviaFitbit
My fitbit hasn't ever been able to update. I just dealt with it
Today though it stopped syncing altogether.
I've tried:
Restart Ionic
Restart phone
Uninstall and reinstall app
Factory reset of ionic
Bluetooth on/off and re pair
Now I'm stuck with a factory reset ionic and it won't set up with my phone. I've tried over and over. It says it finds my ionic but then fails during "connecting" and I've tried all the things it says to do at that point (restart, restart bluetooth etc.)
Any ideas on what to try next?
Best Answer05-21-2019 07:28
05-21-2019 07:28
Hello @Sarahann90 has your situation been resolved or is there still something that requires attention? Please advise and thanks!
Gunny | Richmond, VA (USA)
Ionic Adidas Edition, Versa Special Edition, Aria 2 & Flyer | iPhone & Windows 10
Take a look at the Fitbit Help site for further Assistance & Information.
Best Answer05-21-2019 10:27
05-21-2019 10:27
Best Answer05-21-2019 10:30
05-21-2019 10:30
@Sarahann90 did Customer Service not resolve your issue? If you are still having a problem, please advise and I'll do my best to get everything sorted out for you. Thanks and please advise!
Best Answer05-21-2019 12:34
05-21-2019 12:34
I'm having the same issue. Stopped syncing 5/17. Won't pair.
Best Answer05-21-2019 12:40
05-21-2019 12:40
Hello @jackofclubs and welcome! I would suggest the following:
1. Force Close the Fitbit App on your device.
2. Restart your device.
3. Reset your Ionic.
4. After your Ionic restarts and your device restarts, open the Fitbit App.
5. Attempt to SYNC your Ionic and your device.
Let me know how it goes or if you have any problems., Thanks!
Best Answer05-21-2019 14:16
05-21-2019 14:16
My ionic stopped syncin may 17th too. Tried everything mentioned here.... I removed the device and now i can't install it. Get the same message as this case. Have you resolved the problem? Life my Fitbit Ionic and have been missing the syncing.
Best Answer05-21-2019 14:39
05-21-2019 14:39
Best Answer05-21-2019 14:46
05-21-2019 14:46
Hello @Sarahann90 , I was going to suggest the Factory Reset as a final option, but apparently, you have already done that. I wish I had further options for you!
Hello @Lovise1977 and welcome! A Factory Reset is a viable option for you to try. Have you done this yet and/or are you aware of the process. If you are not familiar with it, I can walk you through it, just let me know.
Thanks!
Best Answer05-21-2019 15:04
05-21-2019 15:04
I have used the last 6 hours to try sync my Ionic. Tried reset, bluetooth on and off, phone on/off, emptied the buffer and more (googled and read a lot of suggestions made by you). Last resort i removed my device 3 -4 hours ago and now i can't get it back in the app. Get the message below before it says it timed out.
So please if factory reset might be an option send me instructions.
My phone is samsung galaxy s7 edge.
Br, Anne Lovise / Norway
Best Answer05-21-2019 16:01
05-21-2019 16:01
05-21-2019 18:43
05-21-2019 18:43
Best Answer05-22-2019 01:34
05-22-2019 01:34
@jackofclubs Glad to hear your back up and running. If you need further assistance, the Community Forum is here to help. Thanks!
Best Answer05-22-2019 01:42
05-22-2019 01:42
@Lovise1977 To Factory Reset, from your Ionic, access the Settings App and scroll down to ABOUT, than scroll down to the Factory Reset option and select it. This will bring your Ionic back to the condition it was when you first received it.
Let me me know if you need further assistance and thanks!
