Ionic not tracking heart rate accurately
As mentioned above, this problem On ionic occurs since March this year. Pls feedback if Fitbit team and/or anyone experienced the same. Many thanks!
1 REPLY 1
@Ct23 Welcome back to the Community. Thanks for getting in touch about this.
For a more accurate heart-rate reading:
  • Wear your Fitbit device on top of your wrist, and make sure the back of the device is in contact with your skin.
  • When you’re not exercising, wear your device a finger’s width above your wrist bone.
  • During exercise, wear your device a bit tighter and higher for an improved fit. The band should be snug but not constricting (a tight band restricts blood flow, potentially affecting the heart-rate signal). Many exercises such as bike riding or weight lifting cause you to bend your wrist frequently, which could interfere with the heart-rate signal if the watch is lower on your wrist.
Additionally, you could check these factors that could affect your heart-rate reading on your Fitbit Ionic .
I'll be around if you have any additional questions.
