01-02-2019 07:42
01-02-2019 07:42
Is anyone else finding that their tracked Fitbit exercise is not transferring to their MFP account?
I’ve done a hard gym session this morning (soon, epilator, treadmill, weights, swim) and although mfp is showing my steps today it’s not showing my tracked exercises?
TIA
01-02-2019 10:42 - edited 02-26-2019 11:33
01-02-2019 11:07
01-02-2019 11:07
Thank you for your reply Rich but this post hasn’t helped I don’t think. It insinuates that it will sync steps which it is doing but the ionic will also record specific exercise too and it them that won’t sync 😫 it’s not a huge problem it’s just a nuisance having to enter them all individually 😡😬
01-02-2019 11:12
01-02-2019 11:12
The link to what we are told that since between Fitbit and MFP clearly says that only Steps and weight will sync. The post says nothing about Fitbit exercises getting synced to MFP. So as far as I can tell, yes Fitbit exercises will not sync or get sent to MFP.
01-02-2019 11:18
01-02-2019 11:18
Sorry yes I understand you answer now #brainfreeze.
Thank you for taking the time to reply.
Hopefully it will be sorted soon?
Annoying though because I nearly went for the Garmin which I know for definite does sync exercise as my friend has a Garmin 😡😡
01-02-2019 16:53 - edited 01-02-2019 16:54
Unfortunately, Fitbit only syncs limited information (e.g. steps) with the Under Armour family of apps: My Fitness Pal, MapMyFitness/Run, Endomondo. These apps do completely sync with Garmin and Apple devices . Hopefully, Fitbit will enable a full sync someday as it does with Strava.
