08-29-2020
07:33
19:09
RicardoFitbit
08-29-2020
07:33
19:09
RicardoFitbit
Hello, I was this summer in a swimming pool to help my son of 2, and after 15 min my iconic stopped working... This is not normal and with this premium watch a deception, what can be the solution?
08-30-2020 19:08
08-30-2020 19:08
Hi @XavierD, welcome to the Community Forums!
Thanks for bringing this to our attention, I understand how frustrating this matter can be for you. To better assist you with this, can you please let me know if the heart rate sensors are flashing or is your device completely unresponsive? If you haven't already done so, I recommend you to check our help article: Why isn't my battery charging on my Fitbit device? and let me know how it goes. Such article includes a restart process which can be really helpful for this situation
Looking forward to your reply.
08-31-2020 12:03 - edited 08-31-2020 12:06
Hello,
Thank you for the feedback.
My iconic is completely inactif and no light is working.
I followed your instructions (for example with the 2 buttons) but unfortunately I did not manage to put it on again. Is there something else I could do?
Best regards
Xavier
08-31-2020 12:11
08-31-2020 12:11
I’ve simply been told by support that it’s down to “one of those things” and they can’t put a reason as to why this happens!
The long and short of it is as follows...
1. If you have a faulty device, like most of us do, you need to contact support and hope you’re under warranty. If you’re under warranty, you stand some chance of getting a device replacement. The support simply tell you to factory rest the device and hope for the best. If that fails, you might get sent a replacement.
2. If you’re out of warranty, you’re going to get a discount at best. A discount on another device that will fail in time, and then repeat the circle of Fitbit life...
Good luck but I think you’re in the same boat as me and screwed.
09-02-2020 10:58
09-02-2020 10:58
Hello,
But unfortunately this did not solve it
What can I do or what process do I need to follow now?
Best regards
Xavier
09-02-2020 16:45
09-02-2020 16:45
Hopefully your device is under warranty.
If it is - then DO NOT swim or shower with the replacement.
If no warranty - then many feel your pain
