05-29-2018
17:25
10:12
MaginB
05-29-2018
17:25
10:12
MaginB
Having issues getting my ionic to restart. Tried a basic restart and a factory reset. Have tried both ways I was told to do it. Called customer service. After having me try to factory reset it said I needed to take a video of myself doing it and send it in. Help please!
Best Answer05-30-2018 02:04
05-30-2018 02:04
It sounds like you have a faulty device.
Have you sent the requested video to customer support? Once you have done this they will be able to assist you further. Depending on your warranty status you will most likely be sent a replacement device.
05-30-2018 05:56
05-30-2018 05:56
It's great to see you around @SunsetRunner!
Thanks for sharing your inquiry, it's great to hear that you've already contacted Support. I totally agree with @SunsetRunner I recommend following Support's instructions so you can get back on track as soon as possible.
Let me know how it goes!
Best Answer05-30-2018 15:01
05-30-2018 15:01
I took a video but gmail will not let Me attach the video. It says it cannot be bigger than 25 mb and the video is 21 mb
