10-11-2019
14:16
17:17
SilviaFitbit
10-11-2019
14:16
17:17
SilviaFitbit
Please don’t upgrade as I have been working with Fitbit support as to why I have.a magenta triangle / exclamation error .
aftter a number iof calls to support and hours trouble shooting with them my problem hasn’t been resolved .
After my firmware upgrade on my ionic my watch would turn off and a two button reboot was needed to get the thing to power up . I called tech support and they had me factory default , remove the Fitbit app from my phone and try to down load the firm wear again . After attempting to down load the image again ( there suggestion) I now get a error code triangle exclamation. I was told at first they would provide a 25 % discount for a new purchase. I refused that since the upgrade cause the problem . Now I have to wait as they escalated this to. Supervisor to view my case .
i have used Fitbit for the 3 and half years and been raining for a marathon and half marathon in thre upcoming month .
Fitbit should do what’s right here !!
17:16
09:28
10-12-2019
17:16
09:28
@Ecuamer Thanks for stopping by. I appreciate the time you took to share your experience with Ionic after you updated it.
Your feedback regarding these updates help us continue improving our Fitbit devices.Thanks for letting us know that you've contacted our Support team and they are already working on your case. Keep in mind that each case is reviewed individually and the option provided is based in the Fitbit Warranty.
Hope I can continue seeing you around.
Best Answer10-12-2019 18:21
10-12-2019 18:21
