07-26-2020 14:48
07-26-2020 14:48
My fit bit Ionic stopped working today while I was swimming in my pool. It has never been an issue until today. I tried to reset and the fit bit vibrated once and the screen was blank, however it was slightly illuminated.
Best Answer07-26-2020 23:53
07-26-2020 23:53
Same problem here, my fitbit also do nothing anymore after swimming yesterday. It happened also last week but after a charge for one or 2 days it returned to working. I am gonna try the next to charge again, but i think this time realy the watch died.
Best Answer07-27-2020 12:12
07-27-2020 12:12
Same problem this week, in my pool too... ionic did not working after swimming. Ionic is not waterproof... warranty was finished...
Best Answer08-24-2020 13:57
08-24-2020 13:57
it seems this is common issue with ionic. Mine has just stopped working too after swimming in salt water. I don't see any sign of water damage on my fitbit though. I just noticed it only had the fitbit logo and seems hang as it's not responding when tapping the screen, so i just let it die. I after i charge it overnight i turn it on and got message "Data not cleared sync and try again" and then it just die by itself. now i can no longer power it on, and it's not charging anymore 😞
Best Answer08-24-2020 15:59 - edited 08-24-2020 16:02
To ALL on this thread. Have a look at previous threads on this issue.
I'm not going to say anything - as I don't wish to sound like a broken record.
This issue has been discussed by forum members many, many times.
If you are in warranty good. If not - bad luck!
The answer for anyone with a working Ionic/Versa or lucky enough to get a replacement is clear.
