05-21-2019
06:20
06:18
YojanaFitbit
05-21-2019
06:20
06:18
YojanaFitbit
Went swimming (local pool) today and after coming out noticed my watch had gone blank. Dried it out and tried charging but nothing showing. Checked and cleaned the contacts, to no avail. I've tried the reset, but nothing shows on my screen. I get a vibration, but nothing visually. Please help
Best Answer03-08-2020 12:06
03-08-2020 12:06
Dear,
I got without any discussion my defect Ionic (after just i year service) replaced, I didnot expected that and had bought already a versa 3 , I now use them both, for swimming I relay mostly on the versa but I also swim eith the Ionic.
Best Answer04-05-2020 06:14
04-05-2020 06:14
My iconic got wet for few minutes and after which it's not working. Just flashing fit bit icon when pressed any key. Tried to do factory reset but dint go through. Rear flashlight not working which initially was. Pl help
Best Answer04-05-2020 06:17
04-05-2020 06:17
Hi has iconic watch problem resolved. If yes then how. Pl guide. Even my watch got wet and after which not functioning
Best Answer04-05-2020 06:23
04-05-2020 06:23
They sent me a replacement as it was a technical problem with the watch.
Best Answer04-05-2020 06:28
04-05-2020 06:28
Best Answer04-05-2020 06:38
04-05-2020 06:38
@curlygirlie Thanks for your prompt response and valuable suggestion. I'm still crossing my fingers in hope that fitbit wouldn't hurt their customer trust and provide best solution.
Best Answer04-05-2020 06:42
04-05-2020 06:42
@YojanaFitbit Hello Madam. My watch has got wet and since then no display except fitbit icon and 0% battery. Rear sensor not working which did for 3 hrs after getting wet. I have bought it with my hard earned money and don't want to loose it. Pl help
Best Answer05-12-2020 01:57
05-12-2020 01:57
This same exact thing just happened to my FitBit after swimming. Tried the factory reset you mentioned below and nothing. It's charged but won't turn on. It's less than one year old, what would you recommend I do to address this?
V/r,
MSgt Pettitt
Best Answer06-21-2020 17:02
06-21-2020 17:02
Exact same thing happened to mine. I bought this wearable specifically to get in the water and track my exercise. Kinda bummed that I got burned with this.
Best Answer06-22-2020 10:02
06-22-2020 10:02
Best Answer08-25-2020 09:38
08-25-2020 09:38
@Parky291 hey my fitbit is doing the Sam's exact thing and did everything you tired. How did you get a,replacement?? Cause it's been 3 days of mine not working
Best Answer08-25-2020 09:48
08-25-2020 09:48
