06-09-2019 15:23
06-09-2019 15:23
Ionic will power up battery indicator shows charging but battery still indicates 0% charge unplugged it and goes straight off plugged back in boot up sequence runs again but still indicates no charge going into device also had a screen pop up showing battery level 0% and no WiFi connection
looks like it’s totally knackered
06-10-2019 19:17
06-10-2019 19:17
Hello @Stevo9324 thanks for bringing this to my attention, I'm happy to give you a hand with your Ionic difficulties and a warm welcome to our Community Forums!
Seems odd that your device is not charging anymore, certainly the 0% that is shown on the display is not a common behavior not the way it was designed. That said, I recommend you to check our help article: Why isn't my battery charging on my Fitbit device? and take in consideration all the tips and steps that are specified there.
Looking forward to your reply if further assistance is required.
